Members FONTENOT Posted July 31, 2020 Members Report Posted July 31, 2020 hi folks im new here , i have a model C clicker . Im trying to get it running without tearing up something the motor turns but it appears to have a lot of drag , i saw lube points on the side of the machine but im thinking the break band and clutch is having some kind of issues . It will come on and turn but my motor gets really hot and then it double clicks then it will just spin and not trip is there anyone who works on these things ? Quote
ljk Posted July 31, 2020 Report Posted July 31, 2020 If it came from humid states and has been sitting it is probably all clogged up. My machine had been sitting outside in Florida for three years and was a mess. Download the manual listed on this post. Lube the bearing on the flywheel hub and back off the big nut a few clicks. Oil clutch, just squirt the brake band. I think the brake may be a little snug from grim are debris. Follow instructions for lubing the motor. The flywheel should spin very easily. There is also some posts on facebook clicker die swap and sell. Quote
Members Tilda Posted January 2, 2021 Members Report Posted January 2, 2021 (edited) Greetings I have recently bought a Idea Model C and have powered it up and had it running. Shortly after it went through a mutli click episode and in the process a piece broke that had been poorly welded. I had it properly welded and put back. It worked again for a little while. Now it has stopped engaging and will not click when triggered. Just makes the electrical sound with no movement This machine was modified to have the dual trigger. I have the manual but am missing pages 40-51. These pages seem to have several figure references. The link in the thread did not include these pages. Does anyone else have them?? (the other link was dead or black.) This is not my strong suit, but I am trying to utilize the manual to do the tedious work needed to know the machine. Any advice on best starts, pitfalls etc? Also, here is a picture of how it was modified for the motor. Edited April 6, 2023 by Northmount replaced heic files with jpg files Quote
Members DavidMillsSaddlery Posted January 12, 2021 Members Report Posted January 12, 2021 That’s not what mine looks like? Quote
ljk Posted January 12, 2021 Report Posted January 12, 2021 Hi Tilda I may be able to make my model c work but your HEIC downloads gives me chest pains. Perhaps if you could send your image in a jpeg I can help. My clicker is now unloaded and working well perhaps I could make a video of the machine in operation. I'm sure the engagement issue can be resolved. tx Lynn Quote
Members DavidMillsSaddlery Posted March 9, 2021 Members Report Posted March 9, 2021 Anyone have photos of how the safety lockout is set up on one of these please? Quote
Members Tilda Posted April 5, 2023 Members Report Posted April 5, 2023 Hello Lynn I was going back to see information on the Ideal Clicker Model C and running through the thread and just now saw you reply, sheesh !! Thank you so much! (I'm not catching any alerts anywhere when someone replies. Anyone with advice on this also appreciated.) I got it running and then I think the lack of lubrication made it break the part again..I repaired the part again and I think I have a fairly good idea on what the problem is, but I'm not sure how to translate the lubrication oils and greases stated in the manual. I would love yours or anyone's advice on how to translate...here are jpgs ; ) of those pages... I'm also gonna attempt to upload a video or link explaining some issues that I encountered somewhere for others that come through this thread.. Here is the Lubrication Schematic for the Ideal Clicker Model C Quote
Members TRC Posted April 14, 2023 Members Report Posted April 14, 2023 would you like to sell a part or two? Quote
Trox Posted May 18, 2023 Report Posted May 18, 2023 Nice machine! It's an advantage to bolt a aluminum plate underneath the hammer head. Especially on these mechanical machines because they hit the dies rather than presses like hydraulic machines. This protects both the head and dies. You can also use double sided dies this way. I do have a German Sandt mechanical clicker myself. I would like to see how they retrofitted these with double triggers, if just the power on switch that wouldn't be any good for these. They need to run some revolution after starting to get some moment on the flywheel, thanks. Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Contributing Member 24VOLTS Posted May 25, 2023 Contributing Member Report Posted May 25, 2023 This is a great topic! I’ve been thinking about purchasing one of these older clickers. They seem to pop up quite a bit on Facebook. There are several brands out there. Is there a brand to stay away from? Generally are parts available others for some of these older models? thoughts all welcomed thanks phill Quote
