Members YSRASupply Posted January 23, 2019 Members Report Posted January 23, 2019 Anyone know where I can get some short post matte black line 20 snaps? I've been searching the web all over but haven't been able to find ay... I typically like to use buckeguy snaps as I find them to be the best quality but unfortunately they don't make a short post version of their matte black snaps. Any help would be appreciated! Thanks! Quote
Contributing Member LatigoAmigo Posted January 27, 2019 Contributing Member Report Posted January 27, 2019 On 1/23/2019 at 5:22 AM, YSRASupply said: Anyone know where I can get some short post matte black line 20 snaps? How about Ohio Travel Bag? This info can be found on page 404 of their current catalog. Quote
Members YSRASupply Posted January 27, 2019 Author Members Report Posted January 27, 2019 Thanks! Didn't think of them as an option but will check out their website! Quote
Rockoboy Posted January 30, 2019 Report Posted January 30, 2019 I needed to install some double cap rivets in something, but I did not have the correct length rivets. So, somebody (thank you Silverback) suggested cutting down the post. I cut the post with sharp side cutter pliers to the length I wanted, then reformed the tube so it was round, and the rivet set exactly like it was supposed to. As snaps are similar to rivets, my suggestion would be "cut that sucker down".. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members YSRASupply Posted January 31, 2019 Author Members Report Posted January 31, 2019 15 hours ago, Rockoboy said: I needed to install some double cap rivets in something, but I did not have the correct length rivets. So, somebody (thank you Silverback) suggested cutting down the post. I cut the post with sharp side cutter pliers to the length I wanted, then reformed the tube so it was round, and the rivet set exactly like it was supposed to. As snaps are similar to rivets, my suggestion would be "cut that sucker down".. Thanks! Will give that a try! I've been having issues with a lot of my snaps cause the cap posts on them are 6.2mm according to the manufacturer but I have been trying to use them on 5oz leather which leaves 4mm of the post exposed... setting these manually with hand setter and maul has led to MANY deformed caps where the post has gone up in to the dome. I was hoping a short post snap would solve the problem. Anyone know how much of the post "should" be exposed before setting? and would a hand press setter like the weaver little wonder or goldstar help with avoiding these sorts of issues? Quote
Members blue duck Posted February 3, 2019 Members Report Posted February 3, 2019 A setter is going to help tremendously with the deformed posts/caps. For now I use a hand held setter, a Pres-n-Snap, that works well for what I need. As for the length, if it is appx. 1/8" above the surface, that seems to work on most leather, for really thin leather, you might try a bit less. It may seem wasteful, but a test snap on a scrap will save you lots of grief. Quote May God Smile on you today.
