Members cdthayer Posted February 8, 2019 Members Report Posted February 8, 2019 My portable compound-feed machine is a Singer 111G156 powered by hand (automotive steering wheel spinner knob), transported place-to-place inside or outside by a surplus folding wheel chair, and used on any sturdy flat surface. It weighs about 65 pounds. Photo shows it setting on a motorcycle air-lift table being used to reattach a purse strap (Tex90 thread). CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
kgg Posted February 9, 2019 Report Posted February 9, 2019 I like the wheel spinner idea. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Gunnarsson Posted February 9, 2019 Members Report Posted February 9, 2019 Others have talked about the difficulty in sewing straight and well while using one hand for cranking, so I believe I would be putting motor on it sooner or later. But sure, if i don't get a suitable one at the same time as the head I will most likely try hand cranking it, it's not like I could have the head available and not try to use it! Quote
Members dikman Posted February 9, 2019 Members Report Posted February 9, 2019 Here's what I did to mount a motor on top. I had a full depth table so cramming it in wasn't necessary for me. Without a big pulley it could be fitted a lot closer. The second photo is the somewhat extreme length I went to in order to slow it right down! If you made a "box" to mount the head on and made it longer then you could almost fit the motor right next to it and in line. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
