I've got a couple of em . . . one is glued to a board, . . .  one is just a piece of leather.
Both have just white jeweler's rouge on them, . . . both sharpen scissors, knives, razor cutters, chisels, . . . and just about anything else I want to slap on there.
Main part is to see (and watch as you use it) black residue being deposited on the strop.  If it is not, . . . no "cutting" action is being done.  If black is being deposited, . . . you are moving metal.
The most important part is not the strop, . . . but the technique, . . . which I cannot teach here, . . . not enough space.  Sufficient to say, . . . practice a bit, . . . check your progress, . . . change what you are doing when it is not working.  It will probably not be the strop, . . . but your technique.
ALWAYS, . . . pull your blade along the strop AWAY from the sharp edge.  Watch your angle, . . . try to duplicate the one the factory put on there.
If you are not sure if you have the right angle, . . . blacken the edge with a permanent black sharpie pen, . . . strop a few times, . . . then look at your tool and see where the black came off.  It should have been completely along the angle of the grind, . . . if not, . . . adjust accordingly.
May God bless,
Dwight
www.dwightsgunleather.com
  • 2 weeks later...
Funny how this thread just came to me this morning.
For the last four years I have been using just a piece of 4 oz veg tan for a strop. No wood, just this sad little piece of leather.
Just last night I finally made a strop for my splitter. I mean literally just last night.
I used a piece of 1x3 poplar and a piece of black drum dyed Herman Oak 8 oz vegtan.
I was going to put a flesh side and a grain side to it. But after taking a wire brush to the grain side for adhesion, I decided I liked the looks of that. So, I glued it scuffy grain side up.
I think it'll do fine.
The bad part of this? I'm a freaking carpenter for Pete's sake. I've had access to wood all this time. And never bothered with making a strop. Guess I'm just lazy.
I think you misspelt 'busy'! :)
Kindest regards
Brian
"Whether you think you can or whether you think you can't, you are right"  Henry Ford
Machines: Singer 201p, Kennedy,  Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Ha, nope.
1 minute ago, bikermutt07 said:
Ha, nope.
Things to do, people to see, place's to go ... then there's family, work, sleeping, life and things get put on the back burner. I do what I can, and leave the rest for another day, but I believe its no good beating myself up over it.
Kindest regards
Brian
