Okay, sort of a short lead up. I’m new here.
I’ve been looking for a used walking foot sewing machine (I know, join the club, apparently) that will work for a newbie.
I think I’m looking for a machine for light to medium duty leather work for bags, and small goods in vegan and chrome tan leather. But I don’t think I’m ready to go whole hog and get a new $2-4,000 machine.
Live been looking at both flatbed and cylinder arm machines such as the conservative and Juki types but I think I’d like to start on a used machine such as the Pfaff flatbed 1245, 545, or the cylinder 335.
So I finally found one available for around $1000 but I think it’s missing a grease housing cover in the craigslist photos so I ended up finding a machine diagram, then a parts list, and then a website that has parts for a reasonable price. Impressive. Check out my findings for a 1245 grease housing front and back:
Diagram list::
https://www.universalsewing.com/tek9.asp?pg=parts_pfaff#expanded scroll down to 1245
then the actual diagram:
 https://www.universalsewing.com/images2/parts_lists/all/6mdl64b0.pdf
Go to page 16 to see the housing that surrounds the transfer gears that power the bobbin. Part numbers
91-141 546-05
and
91-141 545-05
So so I go searching and I find a site that apparently sells these two pieces for under a dollar.
https://www.strima.com/pfaff/cat/pg-484/st-0/k-2002309/
Sure. Great find. But knowing I can replace many of these parts at all is a boon on a machine that’s likely as old as I am! I’m impressed with myself and that got me the nerve to post on this here forum in hopes it helps someone else, too.
Cheers! Also, if you have additional tips for this noob I’m all ears. This forum is fantastic.
Edited by luxuryluke
Images were broken or too large, again to use the correct part names
Handstitcher since ‘17. Newly acquired: Necchi 840-100 RB (rotative binder)
Are you aware that Strima is in Poland and that shipping may be expensive to the USA? You may have to meet a minimum price in the cart to order overseas and outside the EU.
Posted IMHO, by Wiz
Ugh. Welp. Hmm.
Your articles and knowledge are very helpful, Wiz. I think the actual availability of these parts is the solution-breaking part. Sew sad.
3 minutes ago, luxuryluke said:
Ugh. Welp. Hmm.
Some Pfaff parts are very expensive over here. Others not so much. There are Pfaff dealers in the USA who can probably get prices for you on those parts.
Posted IMHO, by Wiz
Thanks, Wiz.
Its a constant risk assessment decision, isn’t it? Budget vs dreams!
It will not hurt running the machine w/o the cover - machines like Singer 111 or Dürkopp 239 have open gears to - that's not an issue at all. Personably I think open gears are even easier to service. Grease filled gear boxed in the hook area can be a "magnet" for lint, thread pieces or broken needle tips - not necessarily but I have found this stuff in gear boxes.
7 hours ago, Constabulary said:
It will not hurt running the machine w/o the cover…
Thanks for the tip, @Constabulary  id not considered that possibility. Thanks!
Newer model 335 bobbin case is $110. Not the hook mind you, just the weird shaped bobbin case. I typically keep more than one case on hand so I can adjust each for different thread weights/tensions. On this machine it's not worth it.
Yeah doesn't look like a sealed cover or reservoir, just more of a "keep your fingers out" and "keep grease from flying everywhere" type of part.
If you run a servo and use slow speeds then grease flinging shouldn't be a problem.
