Members niakulah Posted March 11, 2019 Members Report Posted March 11, 2019 1 hour ago, bikermutt07 said: What kind of sander is it? It's an Axminster. Uses 6x48" belts. Quote
bikermutt07 Posted March 11, 2019 Report Posted March 11, 2019 5 hours ago, niakulah said: It's an Axminster. Uses 6x48" belts. That's an awfully big sander for sharpening. And 60 grit is really aggressive. If you only used the 60 grit, you are going to spend hours and hours hand sharpening to bring it up to sharp. One miss swipe with 60 could take the edge right off and at 6 inches you will find it difficult to control. Unless it has a great table. I wouldn't try it on that sander with that grit. I know lots of people have had good results using the harbor freight 1x32 sander. I went with the Kalamazoo because 1 I'm a buy once cry once guy, and 2 I figured it would have a better table. The truth is, I don't even use the table. I sharpen higher up on the belt and give everything a convex edge. It takes a little trial and error, but once you get it down, it's not hard to use. Quote I'm not paying 80 bucks for a belt!!! It's a strip of leather. How hard could it be? 4 years and 3 grand later.... I have a belt I can finally live with. Stitching is like gravy, it's only great if you make it every day. From Texas but in Bossier City, Louisiana.
Members niakulah Posted March 11, 2019 Members Report Posted March 11, 2019 44 minutes ago, bikermutt07 said: That's an awfully big sander for sharpening. And 60 grit is really aggressive. If you only used the 60 grit, you are going to spend hours and hours hand sharpening to bring it up to sharp. One miss swipe with 60 could take the edge right off and at 6 inches you will find it difficult to control. Unless it has a great table. I wouldn't try it on that sander with that grit. I know lots of people have had good results using the harbor freight 1x32 sander. I went with the Kalamazoo because 1 I'm a buy once cry once guy, and 2 I figured it would have a better table. The truth is, I don't even use the table. I sharpen higher up on the belt and give everything a convex edge. It takes a little trial and error, but once you get it down, it's not hard to use. The 60 grit is for wood so I won't be using that. I meant I'll just buy a 1000 grit for now and not 600,800,1000 like you have. I don't want to spend the night changing from 60 to 600 to 800 to 1000 and back to 60. Quote
Contributing Member Samalan Posted March 11, 2019 Contributing Member Report Posted March 11, 2019 9 hours ago, Big Sioux Saddlery said: Absolutely no need to apologize to most of us for going on amd on about leather tools! I would very much like to see pictures of those tools. There could be some real treasures amongst them. How awesome to have some history on them also! You are very fortunate indeed. I have no idea how to post pictures or take them, but my son dose next time he comes by i'll have him take some pics and post them for me. The docs grandfather did small stuff like purses, also he made some very tiny basket weave stamps like you would use for a watch band. The boxes all this stuff came in are as interesting as the tools them selves, old chest with the wood slats and some paper labels that say Boston. But this box is small around 18"x 18" 20" the other box is a sheet metal box with a ton of rivets to hold the metal on. Everyone who sees them want's to know where i got the cool boxes. Lots of stitching wheels and edge creasing tools, single line double triple. Also homemade letter stencils when i asked how much he wanted for everything he said just take them, i held up one tool and told him this one tool is probably $ 100 bucks, he said i know just take them you know my answer. ! My son and i have a gunsmith shop and i think people want to help out. Another guy came in one day i was doing a holster, i used a piece of wood to draw a line the guy says don't you have a ruler, i said ya I'm just to lazy to get up and get it . then he say's i'll bring you one tomorrow. Next day he pops his head in says can you get the door for me ,he walked in with a machinist tool box, filled with tools he said i would find some rulers in the box . When i asked him why, he said he was moving and didn't want to drag it along, and wanted to give the tools to someone who would put them yo good use. My son and i give generously also, so i guess the old saying is true what go's around comes around. Quote
Members TargetRockLeather Posted March 21, 2019 Members Report Posted March 21, 2019 On 3/11/2019 at 6:16 AM, niakulah said: The 60 grit is for wood so I won't be using that. I meant I'll just buy a 1000 grit for now and not 600,800,1000 like you have. I don't want to spend the night changing from 60 to 600 to 800 to 1000 and back to 60. In my opinion, you should NOT use a belt grinder on a knife you care about unless it has significant damage to the edge. Belt grinding removes more metal than should be necessary. Small chips and dings should be removed with a stone. If the blade is in really bad shape, use a sanding block and work your way up to 1000 grit paper. If the blade edge is in good shape, don't use a belt grinder! Use a stone if it's dull and finish it with a leather strop. Keep using the strop as you use the knife to prevent it from getting dull again. Quote http://targetrockleatherworks.com
Members niakulah Posted March 21, 2019 Members Report Posted March 21, 2019 5 hours ago, TargetRockLeather said: In my opinion, you should NOT use a belt grinder on a knife you care about unless it has significant damage to the edge. Belt grinding removes more metal than should be necessary. Small chips and dings should be removed with a stone. If the blade is in really bad shape, use a sanding block and work your way up to 1000 grit paper. If the blade edge is in good shape, don't use a belt grinder! Use a stone if it's dull and finish it with a leather strop. Keep using the strop as you use the knife to prevent it from getting dull again. Thanks. I currently use a diamond plate and buff stick for maintenance. Was thinking more of sharpening new tools and changing angles and that sort of stuff. For example I bought a new old stock George Barnsley marking knife last year. It took me 2 evenings of sharpening it on the diamond plate to get it usable. And another evening on the buff stick to get it properly sharp and mirror polished. All in all still an enjoyable way to spend my evenings after work. But I'd rather do more leather work. Quote
Members TargetRockLeather Posted March 21, 2019 Members Report Posted March 21, 2019 Oh ok then. I was just concerned because I had this vision of a perfectly good tool being ground away If you need to change the angles (re-profiling) that's a different story. Quote http://targetrockleatherworks.com
