Members katit Posted March 20, 2019 Members Report Posted March 20, 2019 Need help with needle positioner. I got motor pictures. Yes, it's cheap motor. No reducing pulley installed. How should it work? I see red light, it "works" somewhat. But it's not always leaves needle at a bottom when I let off. It would work and it would raise needle on back pedal. But it would randomly not do it and stop machine in random places. I see no pattern on what happens. Using switch to "up" or "dn" doesn't do much other then preventing motor from doing anything. Power-cycle and it seems to start working but then it stops again. Quote
Members dikman Posted March 20, 2019 Members Report Posted March 20, 2019 If there's no reducer setup, i.e. belt is going directly from the motor to the handwheel and it has been set up correctly then it has to be the settings in the menu system (unless it's faulty, of course). Can you post a photo of the setup pages? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members katit Posted March 20, 2019 Author Members Report Posted March 20, 2019 Do you mean instructions or picture of display? I did not change any settings other than rpms. and yes, no reducer Quote
Members dikman Posted March 20, 2019 Members Report Posted March 20, 2019 Instructions.I would think you would have to set it up in the menu as it's likely that it would be turned off by default. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members katit Posted March 20, 2019 Author Members Report Posted March 20, 2019 Instructions attached, however it works but not reliably Quote
kgg Posted March 20, 2019 Report Posted March 20, 2019 Have you contacted the dealer / supplier? They maybe able to offer some suggestions. If you got it from Amazon you maybe able to return it, if from Ebay you maybe out of luck. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members dikman Posted March 20, 2019 Members Report Posted March 20, 2019 These are the instructions from my motor. Note section 3 about setting it up. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members katit Posted March 20, 2019 Author Members Report Posted March 20, 2019 4 minutes ago, dikman said: These are the instructions from my motor. Note section 3 about setting it up. Thanks! I can return motor, but I will give it another try. I think I know why it _might_ act. I don't think belt is very tight and probably it "skips" a little. Maybe machine "inertia" caused it to move too far or something like this. I will get belt tighter and report back.. Quote
mikesc Posted March 20, 2019 Report Posted March 20, 2019 I don't think that doing "back pedal" is what they were set up to accept as "needle up" or "needle down"..doing "back pedal" ( by which I presume you mean "heel down" ) may have banjaxed it..Normally you set needle positioning systems to be 'something" when stopped ( when you stop pressing the pedal forwards..not when you "back pedal" ) either to be either "needle up" ..or "needle down".. Quote "Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
Members katit Posted March 21, 2019 Author Members Report Posted March 21, 2019 Ok! It works now. I think belt might be a culprit. Also, not in my manual but with trial/error I figured that for this motor light need to be on when needle is down. What I have now: When needle "dn" - it goes down when I let off pedal. Heel down - needle goes up. This is perfect sewing setup. When needle "up" in options - it goes up when let off pedal. And nothing happens when heel down. Looks like problem solved and looks like it's crucial to have good belt/tension. Quote
Members dikman Posted March 21, 2019 Members Report Posted March 21, 2019 Good that you got it working. The needle position when the light is on is most likely the answer (which is why I referred to section 3 in my instructions). That light indicates where it will stop. As for the belt tension, it goes without saying that you don't want a slack belt when sewing. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
