Members LeatherLegion Posted April 22, 2019 Members Report Posted April 22, 2019 Would a 1.5amp motor be able to "move" a Nakajima 341 successfully ? I have a servo motor for that machine but having one of those small motors attached to it might save a lot of space as i don't have room for another full size table in my basement. I am planning on using this machine only for up to 6-8oz ..mostly wallets or light bags. Any other suggestion? Any input would be a appreciated Thank you ! Ed Quote
Moderator Wizcrafts Posted April 22, 2019 Moderator Report Posted April 22, 2019 I have one of those tiny motors on a Singer 29k71 patcher. It has a tiny pulley that feeds the larger pulley on the flywheel on the patcher. The speed reduction is probably 15 or 20 to 1. That's what it takes to drive a heavy mechanism. Your machine probably has a smaller pulley than my patcher. Thus, it may require an idler wheel with 3:1 gear reduction to get enough torque to turn the machine over from a dead stop and pierce veg-tan leather. You can find these reducers on the cheapo portable walking foot machines sold on eBay. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members LeatherLegion Posted April 22, 2019 Author Members Report Posted April 22, 2019 46 minutes ago, Wizcrafts said: I have one of those tiny motors on a Singer 29k71 patcher. It has a tiny pulley that feeds the larger pulley on the flywheel on the patcher. The speed reduction is probably 15 or 20 to 1. I guess replacing the flywheel with a larger one will help, without the help of an idler wheel? Will that also slow it down a bit too? Thank you . Quote
Members dikman Posted April 22, 2019 Members Report Posted April 22, 2019 Yes, replacing the flywheel with a large pulley will help, but the best you might get is maybe 10:1 with a 10" pulley, which probably won't be enough based on what Wiz has said. Can you mount the servo on top of the table, behind the head unit? One or two have done that. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Moderator Wizcrafts Posted April 22, 2019 Moderator Report Posted April 22, 2019 2 hours ago, LeatherLegion said: I guess replacing the flywheel with a larger one will help, without the help of an idler wheel? Will that also slow it down a bit too? Thank you . Honestly, these little motors don't have enough startup torque to overcome the weight of the large flywheel on my patcher. I had to spin the wheel with my hand to get it moving. Once in motion the motor could keep it sewing until I stopped the wheel. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members dikman Posted April 22, 2019 Members Report Posted April 22, 2019 Sounds like the little motor could be a no-go. This is what I meant by a top-mount servo. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members tofu Posted April 22, 2019 Members Report Posted April 22, 2019 7 hours ago, dikman said: Sounds like the little motor could be a no-go. This is what I meant by a top-mount servo. Nice setup you have there. How does the pedal work? Quote
Members dikman Posted April 22, 2019 Members Report Posted April 22, 2019 This is the final version. The pedal is the usual arrangement, what I like about many of the servos is the control "box" is a separate unit so doesn't have to be mounted with the motor so is simply mounted underneath. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members LeatherLegion Posted April 23, 2019 Author Members Report Posted April 23, 2019 I might end up bolting the servo motor under my work bench and mount the machine only when i need to use it. I can probably cover the cut-out for the belt with the cutting mat when the machine is not being used . Thanks for your input guys Quote
Members dikman Posted April 23, 2019 Members Report Posted April 23, 2019 Considering you already have the servo it makes sense to use it. Plus it will be a better motor than the little one. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
