Hi, I am hoping to find some help.
I recently purchased a singer 111w155. It worked when I bought it, however, once I brought it home, I haven’t gotten it to function.
The top thread just breaks at the needle, last time it broke the tip of the needle at the eye as well. Thread  seems to get hung up in tensioner like in 1st photo
I have it set at “5” for stitch length. It is 135 thread.
I will attach another pic of resulting leather in next post.
Thank you so so much.
Edited by LizO
Adding pictures that didn’t load 1st time
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
This is what the work looks like
Also, note how I have the spool set, it doesn’t seem right. In the manual, there is an attachment I may be missing. What is it called and where can I get something to replace it?
Yer thread path doesn't look right.  See can we find a pic...
111.jpgThe thread should come OVER the top set of discs (between them) and then go down the RIGHT SIDE of the lower disks.
Go all the way around the lower disks to like 12:00 position, and the spring will "snap in" on the thread, then up to the take-up lever and back down.
Edited by JLSleather
pic
5 leather patterns
I have only ever used a Janome machine for fabric, but here are a few comments
The thread on your machine doesn't seem to be properly routed and doesn't seem to go through the take up lever at all
I had a problem with needles snapping and found that the top thread had become wrapped or looped around one of the wire guiding loops, so it was jamming on them. This meant that the top thread was not moving at all, so as the work was fed through the machine the top thread was pulling on the needle, which quickly snapped
Get hold of a threading diagram for your machine and re - feed the thread carefully all the way to the needle, checking right from the reel of thread and at each stage and guiding hook that the thread runs freely
Check that the thread tensioner is not adjusted too tightly
Check that the upper thread runs freely when the foot is in both the upper and lower positions
Pull both upper & lower threads forward and clear of the foot and similar mechanism
Set up the machine for sewing with scrap leather but only turn it by hand. This will enable you to check if everything is working smoothly. If the upper thread becomes jammed the thread will not be able to run through the eye of the needle. Instead it will pull on the needle and bend the needle away from you slightly, and if you continue it will snap
Alternatively if the needle comes to a sudden stop on something hard & metallic that means the needle is not aligned properly. If that happens besides correcting the fault fit a new needle as even a needle that is blunted so slightly that you don't see it can give you problems
I've just noticed that in the third/bottom picture of your first post the thread is not coming off the reel, it seems as though it is wrapped round the support rod for the reel. Does the reel have a paper label on it, and resting on that? Push the reel all the way down the rod so the reel is resting flush on the top of the machine. Or is it just because it's white thread on a white reel and doesn't show clearly? Check anyway.
Thank you both for your replies.
I actually hadn’t threaded the machine, I was just using the photo for reference.
I do believe I may have been doing something wrong—
   I was hooking the thread behind the pin on the top what I call the tensioner (the one without the wire lever). I didn’t do that and the thread worked better.
However, my problems aren’t completely gone.
please find attached how I threaded it and the resulting work,
If it is tension related- are those the two circular things that the thread runs about? Are they adjusted by turning the screw in the center? Are there any resources I can find so I quit bugging you? I did find some manuals online, but they didn’t really cover troubleshooting.
Again, I appreciate your help so so so so much.
Liz
Edited by LizO
I've just Searched YouTube for "Singer 111w155"
There are loads of videos including several each on feeding the thread, adjusting tension. Just work your way through them and I'm sure you'll find an answer
I've just Searched Google for "Singer 111w155" manual - there are several websites to obtain the manual either as a pdf or a reprinted paper manual
Edited by zuludog
Liz
You are getting closer ...The thread is around the tension discs but not pulled down into them properly. The round nut thing in front of them is what you adjust the top tension with. Turn it clockwise and it will tighten down on the thread and anticlockwise and it will get looser. First get the thread to pull down in between them discs and think of them like they are your thumb and finger gripping the thread....the more you squeeze the harder it is to pull the thread. Squeeze to hard and the thread comes to the top and squeeze to soft and the thread goes to the bottom. Hope that helps you some .
Brian
YouTube Channel
Instagram
Always thread machine with presser foot in raised position to release tension and allow the thread to drop properly into tension disks
Also remember to hold both top and bottom tread securely in your hand when starting the first couple stitches to prevent it from getting tangled and making a mess
My 2 cents
I usually start a sewing machine by hand for the first 2 or 3 stitches to make sure that everything is running OK
That "pin" in the top disks is to keep the disks from spinning around... the thread doesn't go on that.
Looks like you have the thread direction right.  Be sure it snaps down in to the disks (there should be tension on the thread if it's in there).
And then, as rburson states, hold on to the ends of the thread when you start... keep some tension on the ends ... until you have a few stitches in the work
5 leather patterns
