Members Mocivnik Posted July 6, 2019 Members Report Posted July 6, 2019 Does Tandy have some proper stitching chisels to use? I'm talking about 2-4-6 prongs, buying as set from the photo below. I've got the diamond shaped ones from China, they're pretty useless, I think. They're impossible to pull out from nearly just 1 layer of leather, but really impossible to use them at 2 or even 3 layers of 7-8 veg tan at once (or is it that I'm doing something wrong?!). Quote
Members kiwican Posted July 6, 2019 Members Report Posted July 6, 2019 Not sure about your experience level so I'm just throwing this out there. Have you polished them? Quote
Members zuludog Posted July 6, 2019 Members Report Posted July 6, 2019 (edited) 1 hour ago, kiwican said: Not sure about your experience level so I'm just throwing this out there. Have you polished them? Yes, you can improve stitching chisels by polishing the prongs Make a small file or 'wand' yourself by gluing some wet & dry abrasive paper to a thin sliver of wood like a lollipop stick and carefully smooth or polish each prong. It's a slow job but it can give good results. Start with 400 grit, then 800 grit It is easier to remove the chisels if you lubricate the prongs by first rubbing them on some beeswax Hold down the leather with a small block of wood, and make a straight pull, resist the temptation to twist the chisel as you pull it out Tandy have recently changed the way they do business, and have closed a lot of shops. The only shop left in Europe is in Spain, but any goods ordered from Tandy by customers in Europe will be supplied directly from USA, which will involve shipping and import duties So if you have to import items to Slovenia anyway, you could have a look at www.goodsjapan.com and www.leatherhouse.eu Have a look at Nigel Armitage's channel on YouTube; he has reviewed a lot of pricking irons and stitching chisels Edited July 6, 2019 by zuludog Quote
Members Mocivnik Posted July 7, 2019 Author Members Report Posted July 7, 2019 12 hours ago, kiwican said: Not sure about your experience level so I'm just throwing this out there. Have you polished them? Neither am I But the answer is NO. I haven't polished them, because I thought that punches are hardened. (hardened + sandpaper = NO GO). But will give it a go! 11 hours ago, zuludog said: Yes, you can improve stitching chisels by polishing the prongs Make a small file or 'wand' yourself by gluing some wet & dry abrasive paper to a thin sliver of wood like a lollipop stick and carefully smooth or polish each prong. It's a slow job but it can give good results. Start with 400 grit, then 800 grit It is easier to remove the chisels if you lubricate the prongs by first rubbing them on some beeswax Hold down the leather with a small block of wood, and make a straight pull, resist the temptation to twist the chisel as you pull it out Tandy have recently changed the way they do business, and have closed a lot of shops. The only shop left in Europe is in Spain, but any goods ordered from Tandy by customers in Europe will be supplied directly from USA, which will involve shipping and import duties So if you have to import items to Slovenia anyway, you could have a look at www.goodsjapan.com and www.leatherhouse.eu Have a look at Nigel Armitage's channel on YouTube; he has reviewed a lot of pricking irons and stitching chisels Will give it a go! Probably from all 4 sides each spike, right? I know for beeswax but it's taking hell of a long time if I stick it into wax between each punch..I know I'm already super-slow, but this would expand time x10 :/ Twisting the chisel you mean probably from one side to another? Yes, but I got friend going to US for couple of weeks and he said he can bring me 3-4kg pack of items from US :D therefore I decided to spend all the weight on Tandy :D Quote
Contributing Member fredk Posted July 7, 2019 Contributing Member Report Posted July 7, 2019 1. The teeth/prongs will be case hardened. You'd have to file away quite a bit to get through it. A bit of polishing by using a jewellers file or a metal nail file followed by smooth grades of wet & dry grit paper will make a lot of difference. 2. Mix a pot/jar/tin of soft bees wax and olive oil. Not soft and runny, just softer than beeswax on its own. Before you make the first set of holes dip the chisels into the beeswax mix, then as you go on, after about every third time dip the chisels again, if the leather is really dry you may need to dip after every second hit. Quote Al speling misteaks aer all mi own werk..
Members OldGuardDog Posted July 7, 2019 Members Report Posted July 7, 2019 I stopped fighting the chisels. I use them to lightly space the stiches. I use a short length of an ice pick to push the holes through. I mount it in my small drill press, which I have drilled an 1/8" hole in the edge of the table. This allows me to pass the ice pick tip through as many layers of leather as I need. I run the drill press at a medium speed. You can then easily stitch the sheath using blunt needles, and no fighting to pull the thread through. I also cut a groove for the stitching to lay in after pushing in the holes. A few taps on the finished stitch closes the leather fairly tight, since you did not remove any leather, just "pushed" it out of the way. This gives a nice flush stitch. The blunt needles are great- no blood from the pointed ones, and no need for finger cots! Quote
Members billybopp Posted July 7, 2019 Members Report Posted July 7, 2019 You may want to check out stitching chisel reviews by @Dangerous Beans (Nigel Armitage)'s youtube channel. There is a LOT of good information there and a LOT of chisel reviews. https://www.youtube.com/channel/UC8urn9l3pybW5LztUa6zbOA -Bill Quote
Members zuludog Posted July 7, 2019 Members Report Posted July 7, 2019 (edited) 2 hours ago, Mocivnik said: Neither am I But the answer is NO. I haven't polished them, because I thought that punches are hardened. (hardened + sandpaper = NO GO). But will give it a go! Will give it a go! Probably from all 4 sides each spike, right? I know for beeswax but it's taking hell of a long time if I stick it into wax between each punch..I know I'm already super-slow, but this would expand time x10 :/ Twisting the chisel you mean probably from one side to another? Yes, but I got friend going to US for couple of weeks and he said he can bring me 3-4kg pack of items from US :D therefore I decided to spend all the weight on Tandy :D The advice from FREDK is good, do the best you can. Ordinary sandpaper will not work very well on metal, but wet & dry paper will You don't need to rub the chisel with beeswax every time , about every 3 or 4 times is OK. FREDK's tip about softening the beeswax with oil is excellent! I hadn't thought of that, but I'll definitely try it myself in future You should place and remove the chisels at a right angle to the leather where possible. Any kind of twisting, wobbling, or moving from side to side may damage the prongs and/or the leather I have used both types of Tandy stitching chisels - the Craftool Pro with the flat, silver handle, and the Craftool with the round black knurled handle. I think the Pro has slightly finer prongs, but they're both OK. I polished the prongs on both types, which improved them Have a look at Tandy's website and get a shopping list together for your friend. Perhaps you could tell us whereabouts in the US, and some of out American members could give you some advice? Remember that you can use a stitching chisel to just mark the position of the holes, by only knocking it in part way, then making the holes all the way through the leather with an awl Edited July 7, 2019 by zuludog Quote
wizard of tragacanth Posted July 7, 2019 Report Posted July 7, 2019 I think that you would be wasting your money on another set of chisels. There is nothing to be gained by it. They all have the same problem with sticking in the leather. Just suffer with the ones that you already own. We all do! Polishing seems to help a little but not as much as you would hope. Same with bee's wax. I am usually going through two layers of leather that add up to 8mm thickness, and that is right to the top of the tines of the chisel. I put wax on the tips of the tines, tap the chisel in about half-way, take it out, wax it again and then go all the way through. Using a wood block helps but even with that, if I didn't wiggle the tool to get it out, I would never get it out. The only way to make it easier is to use chisels with fewer tines. I would not even think about using a chisel with more than four tines. But that is from an old man who doesn't have much grip strength any more, YMMV. nick Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
Members SShepherd Posted July 8, 2019 Members Report Posted July 8, 2019 16 hours ago, Mocivnik said: Neither am I But the answer is NO. I haven't polished them, because I thought that punches are hardened. (hardened + sandpaper = NO GO). But will give it a go! Will give it a go! Probably from all 4 sides each spike, right? I know for beeswax but it's taking hell of a long time if I stick it into wax between each punch..I know I'm already super-slow, but this would expand time x10 :/ Twisting the chisel you mean probably from one side to another? Yes, but I got friend going to US for couple of weeks and he said he can bring me 3-4kg pack of items from US :D therefore I decided to spend all the weight on Tandy :D Unless they're case hardened, which I highly doubt, sanding/polishing will not effect them (that's how you sharpen a knife). You only have to worry if you're using them on powered grinder and bring the heat up past the temp. they were tempered at. Your fingers will burn first Quote
