Members SilverForgeStudio Posted July 7, 2019 Members Report Posted July 7, 2019 I have been given a roll of seat belt material... and I want to use it for some keepers (Tool holders) or straps for a few projects. In order to do this I need to sew it to itself on the ends- what needle do I use? I do not have experience with this. I realize a "Bar tacking" machine would do it- dont have one of those... These will not see heavy loads or tactical use- I was going to "Buttonhole" stitch 3 times across the overlap area with a couple of vertical button hole stitches in the middle ( Think -|-|- for a visual) Im thinking as this material is woven nylon I would not want to use a sharp needle as it would cut more fibers- So use a blunt needle and power through it? Quote
Contributing Member LatigoAmigo Posted July 8, 2019 Contributing Member Report Posted July 8, 2019 5 hours ago, SilverForgeStudio said: So use a blunt needle and power through it Consider using a tapestry needle... blunt tip, big eye for big thread. Quote
Northmount Posted July 8, 2019 Report Posted July 8, 2019 Seat belt material is a very tight weave. Suggest a regular conical point needle. You'll never get a blunt tip through unless you use an awl to make a large hole first. Don't use triangular point glover's needles. Tom Quote
Members SilverForgeStudio Posted July 8, 2019 Author Members Report Posted July 8, 2019 Thank you both- I will be doing this on an older singer domestic. I have both tapestry and conical point (thanks mom for giving me all the sewing room stuff)... so Im going to see how this affair goes- may be a fail- maybe not. I hope to post pics Quote
