Members DV8DUG Posted July 12, 2019 Members Report Posted July 12, 2019 So I went to my local Lowe's to pick up some denatured alcohol and wasn't able to find it on the shelf... or the spot on the shelf with price tag where it was supposed to be. I asked the paint counter girl what was up and she informed me that CA has banned denatured alcohol and several other high VOC solvents. Acetone was on the shelf as well as several very caustic and smelly paint strippers. Confused, I searched the internet for an explanation and found little to nothing about this issue. I was able to secure what I needed at a local ACE hardware store and they had piles of gallons sitting on shelves. Anyone else have similar experiences and do I need to stock up? Quote I think of Chinese food when I think of life; That's sweet and sour. My life is sweet as saccharin. Ye Scurvy Dog. Swords, Weapons, Dungeon Furniture, Custom Leather Work, and More...
Members billybopp Posted July 13, 2019 Members Report Posted July 13, 2019 I'd stock up enough to keep going until I left CA. - Bill Quote
Members DV8DUG Posted July 13, 2019 Author Members Report Posted July 13, 2019 12 hours ago, billybopp said: I'd stock up enough to keep going until I left CA. - Bill You said a mouthful there. Quote I think of Chinese food when I think of life; That's sweet and sour. My life is sweet as saccharin. Ye Scurvy Dog. Swords, Weapons, Dungeon Furniture, Custom Leather Work, and More...
Members Eirewolf Posted March 26, 2023 Members Report Posted March 26, 2023 (edited) I ran into this same problem recently! I am about to run out of denatured alcohol, and I can't find it locally. Tandy won't even sell Fiebing's dye reducer to California anymore. Please help! What can I use as a substitute for denatured alcohol? (I usually cut dyes 50% with it.) I usually use Angelus dyes, Fiebing's dyes, or Fiebing's Pro Oil dyes. Edited March 26, 2023 by Eirewolf Adding information Quote ~~Erin~~ -- Eirewolf Creations masquerade masks, eye patches & accessories
MikeRock Posted March 26, 2023 Report Posted March 26, 2023 Good old Everclear booze....... 95 proof. Quote
Members billybopp Posted March 26, 2023 Members Report Posted March 26, 2023 9 hours ago, Eirewolf said: I ran into this same problem recently! I am about to run out of denatured alcohol, and I can't find it locally. Tandy won't even sell Fiebing's dye reducer to California anymore. Please help! What can I use as a substitute for denatured alcohol? (I usually cut dyes 50% with it.) I usually use Angelus dyes, Fiebing's dyes, or Fiebing's Pro Oil dyes. Try 90%+ isopropyl alcohol, found at drug stores. - Bill Quote
CFM chuck123wapati Posted March 26, 2023 CFM Report Posted March 26, 2023 8 hours ago, MikeRock said: Good old Everclear booze....... 95 proof. ironically though you can buy the alcohol that kills you , ruins lives and families, and is statistically far more dangerous. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members TomE Posted March 26, 2023 Members Report Posted March 26, 2023 Can't help with CA but I've purchased Klean-Strip Fuel denatured alcohol at several Walmarts in our area. I think it was in the camping/sporting goods section. Quote
Members Eirewolf Posted March 27, 2023 Members Report Posted March 27, 2023 16 hours ago, TomE said: Can't help with CA but I've purchased Klean-Strip Fuel denatured alcohol at several Walmarts in our area. I think it was in the camping/sporting goods section. Thanks everyone! Klean-Strip Fuel denatured alcohol is what I used to use, but alas, 'tis nowhere to be found 'round these parts nowadays. Is 90%+ isopropyl alcohol very similar to that when cutting dyes? Quote ~~Erin~~ -- Eirewolf Creations masquerade masks, eye patches & accessories
Members TomE Posted March 27, 2023 Members Report Posted March 27, 2023 (edited) 6 hours ago, Eirewolf said: Thanks everyone! Klean-Strip Fuel denatured alcohol is what I used to use, but alas, 'tis nowhere to be found 'round these parts nowadays. Is 90%+ isopropyl alcohol very similar to that when cutting dyes? I would give it a try. As you probably know, isopropyl alcohol has an extra methyl group in comparison to ethanol. The chemical properties of these 2 alcohols are more similar than different in my experience as a biochemist. You might see different behaviors when dissolving a solid in these alcohols, but I doubt you'd see a difference when diluting alcohol based dye by 50% in either of these solvents. I dilute Fiebings Pro Dye with an equal volume of Tan Kote or Martin's Edge Solution for dyeing and burnishing edges in one step and this works great! I am careful to mix the solution before each use. The MSDS for Fiebings Dye Reducer does not list the ingredients but this post suggests ingredients for dye reducer. Edited March 27, 2023 by TomE Quote
Members DoogMeister Posted March 27, 2023 Members Report Posted March 27, 2023 have only used 91% isopropyl alcohol with good results. Quote
Members Eirewolf Posted March 29, 2023 Members Report Posted March 29, 2023 Thanks so much everyone! I will try the isopropyl alcohol. If anyone else has experience using it to cut dyes (or has more suggestions for other alternatives), I'd love to hear about it! Quote ~~Erin~~ -- Eirewolf Creations masquerade masks, eye patches & accessories
Moderator bruce johnson Posted March 30, 2023 Moderator Report Posted March 30, 2023 I never used anything but isopropyl rubbing alcohol for thinning dyes. It is dirt cheap and available at every corner drug store. When I was doing leather a bunch, I'd buy it by the gallon. I never saw a difference between the rubbing alcohol and higher percentages with my dye formulas. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members cord1974 Posted April 6, 2023 Members Report Posted April 6, 2023 I think it was Aaron from Makers who said Peter Main uses rubbing alcohol as a dye reducer. I've used it in the past as well denatured alcohol. I can't tell any difference. Quote
