So in the above Afrikaans language exchange between Wreford and I he asked if I wet formed the sheath and if it retains the pocket knife well? In my reply I explained that I first completed the construction and dye before I lightly sprayed the inside of the sheath, wrapped the knife in cling wrap plastic, stuck it into the sheath and allowed it to dry overnight. I added that the knife fits snugly - not so that it's difficult to draw, especially when I'm "confronted" with a piece of biltong that needs carving up for a snack... :unsure:
"People are more violently opposed to fur than to leather because it's safer to harass people in coats than to try being nasty to motorcycle gangs." ~Anonymous
  • 1 month later...
I don't know... I think it looks really nice to me!  Stitching is even and looks great!
Keep in mind, we are all artists.. and have our own interpretations on the designs we come up with.
I like it!  It looks functional and very professional.
Vikefan
I like it alot, so ive been away for a little while. What size punches are you using? Also what is the belt is 2" wide.
I don't see anything wrong with it! Good job.
Riem
If you have access to a food vacuum machine, another way to do that holster would be to wet the leather, wrap the knife in cling film, then place a piece of wood inside the plastic bag then the knife in the centre of it and place the leather over the knife in the correct position, You then start the vacuum machine and at the same time press around the knife until you have the required fit. then leave it sealed in the vacuum for about 12 hours and then release the vacuum and let the leather fully dry out. when dry lay it over the back panel and sew etc. you will have a very tight fitting holster and the back piece will be flat against your body
https://www.aldi.co.uk/vacuum-food-sealer/p/096408298075500?gclid=EAIaIQobChMI_NKN_tKb5QIVQuDtCh1JUw8AEAQYBSABEgJDAvD_BwE&gclsrc=aw.ds
Edited by chrisash
Mi omputer is ot ood at speeling , it's not me
  • 2 weeks later...
Apologies friends - I missed a couple of the later comments and feedback.
 Vikefan
@Vikefan
 thanks for the compliments. Really appreciate it!
@Goblin210
Thanks for the comment! I didn't use punches at all, only an overstitch wheel and a diamond awl. It is meant to be worn on a 38 mm wide  belt.
@toxo
Thank you very much!
@chrisash
Thanks for the tip - will do so if I make another of these. Not sure if the wife will consent, but hey, live and learn! :-)
  • 2 months later...
Made a 'lil brother pancake sheath for the red Swiss army knife I usually have in my pocket. 'Lil brother to the larger sheath I posted about in August, so I'm showing them together. The new sheath is a bit of a chance I'm taking on a 1 - 1.2 mm vegtan kip leather I purchased recently. Not sure if it will be durable enough for longer term carry. Stitched up with a red 0.5mm TSA (three strand acrylic) Chinese "upholstery" thread. Feedback welcome.
Front view:
Back view:
