toxo Posted August 26, 2019 Report Posted August 26, 2019 This is my first leather project of any kind. As part of her job my daughter did a weeks course out at Heathrow and I wanted to do something nice to reward her good work. I chose Motoko because it uses minimal techniques/tools and no skiving. I used 2.4mm pull up antique leather which proved problematical at times because it was quite soft.This has taken quite a while because I questioned my ability at every stage and so would test on scrap before I did the deed. I made mistakes and learned from them. In one respect the build was shortened because I knew the strap length and so I didn't have to do an adjustable strap. In another respect it took longer because I incorporated a security measure that took longer than normally necessary. Because she's out quite a lot of the time with her laptop and work files I wanted her to be safe from the scrotes on mopeds who would slice through the strap so I incorporated a 2mm stainless steel cable in the middle of the strap. Took a bit of fiddling but I got it done. Can't seem to be able to load a pic with the strap in place. Try again later. Quote
Members Seagrove59 Posted August 26, 2019 Members Report Posted August 26, 2019 excellent work, like the cable idea, would be good for a travel bag as well. Brass works very well with leather colour. Does she find the handle comfortable, looks like you would need a large hand, could just be the angle it was photoed. Quote
toxo Posted August 27, 2019 Author Report Posted August 27, 2019 3 hours ago, Seagrove59 said: excellent work, like the cable idea, would be good for a travel bag as well. Brass works very well with leather colour. Does she find the handle comfortable, looks like you would need a large hand, could just be the angle it was photoed. Thanks Seagrove. A couple of ideas I would do over. I think a rolled over handle would look/feel better. An extra rivet or two at the top of the buckle strap . An extra row of stitches where the front attaches to the back would be wise I think and the two inside full length pockets could've bee thinner leather. Quote
Members SilverForgeStudio Posted August 27, 2019 Members Report Posted August 27, 2019 @toxo I love it- a family member bought the pattern for me to make them a Motoko as well- nice to see one done outside the video! I will now firmly heist your cable idea into my work- I deal with quite a few travelers and security contractors this would appeal to! Excellent idea for the strap- Ive been doing faraday cage wraps with stainless steel mesh in some canvas items- this may make the jump into leather as well. Bravo for the thought and the implementation! A question if I might- do you find the 2.4mm leather to be too floppy? More importantly does your daughter find it too soft? Bravo Toxo. Quote
toxo Posted August 27, 2019 Author Report Posted August 27, 2019 34 minutes ago, SilverForgeStudio said: @toxo I love it- a family member bought the pattern for me to make them a Motoko as well- nice to see one done outside the video! I will now firmly heist your cable idea into my work- I deal with quite a few travelers and security contractors this would appeal to! Excellent idea for the strap- Ive been doing faraday cage wraps with stainless steel mesh in some canvas items- this may make the jump into leather as well. Bravo for the thought and the implementation! A question if I might- do you find the 2.4mm leather to be too floppy? More importantly does your daughter find it too soft? Bravo Toxo. Thanks Silver. Don't think the thickness is the problem. I think maybe it's the antique/pull up process that makes it softer. It's good for the panels but a sod for edges. Think normal veg tan would be easier. This has been quite a journey, Apart from the hand stitching it's taken months to get my old Durkopp working properly and I needed it for the strap. This is the first time it's done more than about a foot of stitching before something went wrong. I was praying with every stitch on that strap but the old girl didn't let me down, in fact I let her down because with only five stitches to go I didn't realise the end of the steel cable had wandered and bang. finished it by hand. She did really well. The strap ends were challenging. I didn't want just one layer of this leather holding everything so I inserted another shorter piece which meant that my longest normal rivets weren't long enough to go through five layers. The rivets in this picture (the bottom two) were taken out and replaced with copper rivets and roves which were brilliant for the job. Also, looking at this picture reminds me that I intended to add a rivet to each end of the handle but forgot to do it. It's not far away if I do need to do it. And my daughter absolutely loves it which makes it all worthwhile :) Quote
toxo Posted August 27, 2019 Author Report Posted August 27, 2019 Just found this pic of the inside. The sides are reinforced with thick hard chrome tanned leather but I didn't want it too dark so used thick veg tan on the bottom. I guess this reinforcing helps maintain the shape. As you can see I used the same leather for the pockets (full length on the front panel). These could have been much thinner. Quote
Contributing Member LatigoAmigo Posted August 27, 2019 Contributing Member Report Posted August 27, 2019 Very nice bag, and a GREAT story. Keep up the good work! Quote
toxo Posted August 27, 2019 Author Report Posted August 27, 2019 Thank you Amigo. Appreciate it. Quote
Members HoneycuttMachine Posted September 6, 2019 Members Report Posted September 6, 2019 I think its fabulous! A true heirloom, that case not only beautiful but heavy duty. I love the cable in the flat strap, diesel! I think the flat strap is the way to go, with a laptop, notebooks, books, etc. that thing can get heavy. The wider strap will help with shoulder rubs and distribute the weight better. You may even consider a sheepskin on leather adjustable pad for her should it dig into her shoulder when loaded. A fantastic job for an experienced leather worker, you taking this on as a first project is inspirational! Great work and thanks for sharing. Jerry Quote
toxo Posted September 7, 2019 Author Report Posted September 7, 2019 14 hours ago, HoneycuttMachine said: I think its fabulous! A true heirloom, that case not only beautiful but heavy duty. I love the cable in the flat strap, diesel! I think the flat strap is the way to go, with a laptop, notebooks, books, etc. that thing can get heavy. The wider strap will help with shoulder rubs and distribute the weight better. You may even consider a sheepskin on leather adjustable pad for her should it dig into her shoulder when loaded. A fantastic job for an experienced leather worker, you taking this on as a first project is inspirational! Great work and thanks for sharing. Jerry What you've just said are words that everyone will appreciate. You looked at it, you added constructive criticism, you applauded my attempt and I can't say how much I appreciate it. Thank you very much. Quote
