Members dougfergy Posted August 29, 2019 Members Report Posted August 29, 2019 (edited) Just finished up this sheath and I swear to never make one like this again! It is a whole cow. Still can't seem to pull off stitching through this thick of material and get it looking presentable on the back. My awl isn't long enough to go through an inch of leather so I had to awl through each layer at a time and somehow it still got wonky on the back. Then the holes didn't line up when I went to stitching it so I'm stuck with it. Knife is a Texas Knifemaker Supply blade that I did all the scale and guard work on. I don't have the resources to forge a blade or I'd be doing that too. Plenty of flaws but it was a "fun" project. Knife is 15" long give or take a bit. Edited August 29, 2019 by dougfergy Quote
Members TSes Posted August 29, 2019 Members Report Posted August 29, 2019 Great job on the leather work and the scales. What I like to do on a knife with a wide finger guard, is to taper the spacer pieces so that they are thick at the top, and thin at the bottom. That way the guard fits in correctly, and the sheath tapers down so there is no spacer (or just a small amount to protect the stitching) on the lower part. Really helps on the stitching. Quote
wizard of tragacanth Posted August 29, 2019 Report Posted August 29, 2019 Really beautiful. Love everything about it. Would it have been possible, or practical, to drill the holes on a drill press? If you could glue the layers, mark the holes and drill all layers at the same time, I think it could work. You would have to drill through the back so that the sheath would lay completely flat, so that the holes come out "right" on both sides. nick Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
Members Riem Posted August 29, 2019 Members Report Posted August 29, 2019 Very, very nice! And despite the slight unevenness of the stitching on the back, it is a great cover for a fearsome knife... Holy smoke - what a blade that is! Best to keep it sheathed and at ease in such a nice yard of cow... Quote "People are more violently opposed to fur than to leather because it's safer to harass people in coats than to try being nasty to motorcycle gangs." ~Anonymous
Members dougfergy Posted August 29, 2019 Author Members Report Posted August 29, 2019 (edited) Thanks y'all. 2 hours ago, TSes said: Great job on the leather work and the scales. What I like to do on a knife with a wide finger guard, is to taper the spacer pieces so that they are thick at the top, and thin at the bottom. That way the guard fits in correctly, and the sheath tapers down so there is no spacer (or just a small amount to protect the stitching) on the lower part. Really helps on the stitching. I actually started out with that wedge shape in mind but I talked myself out of it afraid I would screw up the holes with the transition. Who knew? 53 minutes ago, wizard of tragacanth said: Really beautiful. Love everything about it. Would it have been possible, or practical, to drill the holes on a drill press? If you could glue the layers, mark the holes and drill all layers at the same time, I think it could work. You would have to drill through the back so that the sheath would lay completely flat, so that the holes come out "right" on both sides. nick Thank you! If I ever build another one that thick, I may try that. Might glue some layers of scrap together to see if I can master that. I did make a needle out of a brass pin that is very sharp and polished that will go in my drill press so that I can bore the holes and burnish the edges as it goes through but I haven't practiced with that either. I definitely want to learn how to pull this off and make it look good! Edited August 29, 2019 by dougfergy Quote
Members dougfergy Posted August 29, 2019 Author Members Report Posted August 29, 2019 44 minutes ago, Riem said: Very, very nice! And despite the slight unevenness of the stitching on the back, it is a great cover for a fearsome knife... Holy smoke - what a blade that is! Best to keep it sheathed and at ease in such a nice yard of cow... Thank you! I've had that blade for almost 10 years and finally decided to finish it so I can work on some more practical knives I have blades for, for Christmas gifts. I'm glad to be done with it. I started off with some burled mesquite wood that I screwed up so I was forced to go with the laminate. The knife is too large for practicality unless you are Rambo or The Rock. Quote
Members noobleather Posted August 30, 2019 Members Report Posted August 30, 2019 Really nice colour and stamping on the front!I like the cutout on the strap handle to show off the star on the handle. Thanks for posting Quote
Rossr Posted August 30, 2019 Report Posted August 30, 2019 Looking good! Clean work imo. Keep it up each one you will get better! Ross Quote
Members dougfergy Posted August 30, 2019 Author Members Report Posted August 30, 2019 Thanks for the compliments and the critique. I noticed I smeared some antique over the front stitching in a couple places so it looks like some dark spots. It came off the waxed thread when I rubbed on it. It would be a long list if I told you all the mistakes I made and had to adapt to. Even though I drew it up and cut out a pattern, I still did a lot of designing on the fly. That's what makes leather work interesting. It's like hitting that one good shot out of 125 swings when learning how to play golf, it brings you back for another round. Quote
Rossr Posted August 30, 2019 Report Posted August 30, 2019 5 minutes ago, dougfergy said: Thanks for the compliments and the critique. I noticed I smeared some antique over the front stitching in a couple places so it looks like some dark spots. It came off the waxed thread when I rubbed on it. It would be a long list if I told you all the mistakes I made and had to adapt to. Even though I drew it up and cut out a pattern, I still did a lot of designing on the fly. That's what makes leather work interesting. It's like hitting that one good shot out of 125 swings when learning how to play golf, it brings you back for another round. Doug, We are our own worst critics always. I can tell you how many times I look at something I finished and all I see are the myriad of mistakes. I show it to friends or clients and they are thrilled with the product and rarely see any of the stuff I do. Like you said its what keeps us coming back and getting better each time I suspect no matter how many things you make you always find stuff to improve next time. The mistakes change and usually are not as major the more you make !!!! In regards to making knives You mentioned you dont have the resources to forge a blade. There are lots of ways to do that. Some of the first knives I made were done with an angle grinder, file and sand paper. Heat treat was in a wood stove(not ideal hahaha). You can do stock removal which other than the heat treat doesnt require forging its just shaping the metal and heat treating. You obviously can handle the shaping of the guard and the handles so I am sure you can do the metal work. Lot of fun! Theres also a book called the $50 knife shop by Wayne Goddard. Lot of ways to make knives on a budget with minimal stuff in it. Enjoy the journey that is the most important part. I firmly believe that part of you goes into everything you make and when you are enjoying it the better the product you make! Ross Quote
