Northmount Posted November 30, 2019 Report Posted November 30, 2019 14 hours ago, ddct70cc said: enlarged the pattern to 120% The bag, or the welted seam? The hole spacing for the welted seam can't be scaled up. Just add more holes and make it longer. And of course if you leave gaps in any joins, stuff will fall through. Tom Quote
Members ddct70cc Posted November 30, 2019 Author Members Report Posted November 30, 2019 Why can the welted seam not be scaled up? How would you go about making a larger spacing between the holes if you do not increase the scale? Quote
Northmount Posted November 30, 2019 Report Posted November 30, 2019 37 minutes ago, ddct70cc said: Why can the welted seam not be scaled up? How would you go about making a larger spacing between the holes if you do not increase the scale? To begin with, I would say that the spacing of the holes and the size of the holes depends a lot on the thickness of the leather. And it only makes sense that if you don't want gaps large enough for small stuff to eventually fall through, that means the holes have to stay close together, as in the original patterns. This is all my opinion as I haven't made any projects using this seam yet. I have been collecting information and photos to use it some day. Tom Quote
RockyAussie Posted December 1, 2019 Report Posted December 1, 2019 22 hours ago, ddct70cc said: Unfortunately, when you do that, it leaves a large, gaping hole at the bottom of the seam where it needs to be solid to hold small items inside the bag I would need to see a picture of this to understand I think. When I have done any patterning on this it has been with regard to the size of hole punch I want to use firstly. Either side of the pattern has to have the holes falling exactly between the holes on the other side. As you can see in my drawing above the hole size is exactly the width between the holes as the hole size itself. the distance in from the edge to the centre of the hole is determined somewhat by the leather thickness but also for setting the thickness that I want the pouch to be. In the pictures above showing the pouch I made for a phone, I decided that a 7mm punch centred at 14mm apart would work and 8.5mm in from the edge to the centre of the hole. This gives roughly a 17mm opening inside the pouch when weaved together. If I wanted a wider opening I could come in from the edge further as long as the pattern was made larger for the article to be placed within later. depending on the leather stiffness it may need to have the tabs that get woven in to be glued down as well to form the box shape more. This is fairly easy patterning with Cad drawing programs but a fair lot of work without I would think. I must add that how I describe the method above is only one that I worked out for myself and other people may use other methods which may be better. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Contributing Member fredk Posted December 1, 2019 Contributing Member Report Posted December 1, 2019 I've been following this on the Q-T. Interesting construction method. I've finally got my head around it. Now to design somat I can use it on Quote Al speling misteaks aer all mi own werk..
Members ddct70cc Posted December 1, 2019 Author Members Report Posted December 1, 2019 20 hours ago, Northmount said: To begin with, I would say that the spacing of the holes and the size of the holes depends a lot on the thickness of the leather. And it only makes sense that if you don't want gaps large enough for small stuff to eventually fall through, that means the holes have to stay close together, as in the original patterns. Thank you for explaining that, Tom...that makes sense now and I’ll try to keep that in mind when I make the pattern. 17 hours ago, RockyAussie said: I would need to see a picture of this to understand I think. When I have done any patterning on this it has been with regard to the size of hole punch I want to use firstly. Either side of the pattern has to have the holes falling exactly between the holes on the other side. As you can see in my drawing above the hole size is exactly the width between the holes as the hole size itself. the distance in from the edge to the centre of the hole is determined somewhat by the leather thickness but also for setting the thickness that I want the pouch to be. In the pictures above showing the pouch I made for a phone, I decided that a 7mm punch centred at 14mm apart would work and 8.5mm in from the edge to the centre of the hole. This gives roughly a 17mm opening inside the pouch when weaved together. If I wanted a wider opening I could come in from the edge further as long as the pattern was made larger for the article to be placed within later. depending on the leather stiffness it may need to have the tabs that get woven in to be glued down as well to form the box shape more. This is fairly easy patterning with Cad drawing programs but a fair lot of work without I would think. I must add that how I describe the method above is only one that I worked out for myself and other people may use other methods which may be better. That is extremely helpful info!!! I hope I’m able to fully grasp the math and geometry involved so that my pattern will work out. Sadly, I do not have Illustrator, AutoCAD, etc. so this is all being done by hand. Thanks again to everyone for helping me out here. Great information to have!!! Quote
Contributing Member fredk Posted December 2, 2019 Contributing Member Report Posted December 2, 2019 Is it better to have a. just one set of holes cut through to from the edge? b. to cut the sides of that cut to an 'arrow head', or just trim them a bit, or need they be trimmed at all? I'm thinking, trimmed to an 'arrow head' might be removing too much material for the gripping, not trimmed and the bits might not lie flush too well, just a little trimming will help them get through the other hole but yet have enough material to grip ?? Quote Al speling misteaks aer all mi own werk..
RockyAussie Posted December 2, 2019 Report Posted December 2, 2019 4 hours ago, fredk said: Is it better to have a. just one set of holes cut through to from the edge? b. to cut the sides of that cut to an 'arrow head', or just trim them a bit, or need they be trimmed at all? I'm thinking, trimmed to an 'arrow head' might be removing too much material for the gripping, not trimmed and the bits might not lie flush too well, just a little trimming will help them get through the other hole but yet have enough material to grip ?? It can be done to some degree with one set of holes cut to the edge but it is quicker and easier to weave them together when both sets are done. (once you get the hang of the technique. Do 2 strips with evenly spaced holes and slits and see what I mean. Where possible it is better to not have any arrow head but when you do a curve join it is necessary in order to give the leather somewhere to go with out needing to overlap. I do not recommend putting in curved corners as I did as it is very hard to get around weaving the curve together. I ended up cheating on the base line and stitching both sides closed on the hole outsides in order to stop them coming apart as I tried to get around the corners.It worked but was an unnecessary part of the design unless you want to do it in expensive exotic skin where using small pieces become desirable. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
Contributing Member fredk Posted December 2, 2019 Contributing Member Report Posted December 2, 2019 thank you Quote Al speling misteaks aer all mi own werk..
RockyAussie Posted December 2, 2019 Report Posted December 2, 2019 yr welcome Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
