Hi, i own a Pfaff 346-H3, the double needle version of the Pfaff 335. I have this problem where the left needle scrapes the ring of the left bobbin assembly. When that happens the thread and/or needle breaks. Usually i only sew with te right needle but at this moment i'm working on a workpiece that is to large to fit under the arm. On closer inspection you can see that the left bobbin case assembly is closer to the feed dog than the right case assembly. Also you can see needle scraping marks on the assembly. I've loosend all the screws i saw but still it cannot move. I have loosened all the related screws I saw, but there is no movement yet. Does anybody have experience with this?
Forward thanks!
  • 2 months later...
There has to be a way to move the left saddle  for the hook.    Take the left hook out and send us a few close ups of the left saddle.
glenn
There's 2-screws one in the front & one in the back @ the same place.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Have you checked the manual about how to adjust the position for using a different needle spacing? That may tell you how to move what you need to move.
  • 1 month later...
Hi! Thanks for your reply, i have not looked at leatherworker eversince and now i have a few replys :). I already loosend and removed the screws but the left hook assembly is still rock solid. I thought maybe there will be some more screws i'm missing.
Good suggestion. I've cheched the original manual but i did not find how to change it. It tells me how to change the needle but not how to account for a different spacing.
With the screws removed, could there be dried oil keeping it frozen acting like a glue?
Maybe it is stuck,you might want to tap the casting it alittle (carefully) w/a hammer & screwdriver.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Very, very  carefully as Bob says!!!!
glenn
