Contributing Member Ferg Posted June 10, 2025 Contributing Member Report Posted June 10, 2025 You are putting wrong angle on blades. Sharpened area should be no more than one or two mm back from cutting edge. You have filed the edge at least 60 degree angle when they should be right at 30 degrees. Fine grade file that is new and finish with about 600 grit stone. Quote
Northmount Posted June 10, 2025 Report Posted June 10, 2025 (edited) 1 hour ago, Hardrada said: Probably using a VPN. Like you are? Your IP address resolves to Staré Město, Moravskoslezský, 738 01, Czech Republic. Most often, IP addresses from India, Pakistan, etc. are spammers. They will join Leatherworker.net, pretend to be good members, often post a reply to a thread that hasn't seen any activity for several years. This thread had none for 2 years. Their double post tends to raise flags as well. So I was poking a hornets nest with a stick! Edited June 10, 2025 by Northmount added content Quote
Contributing Member Ferg Posted June 11, 2025 Contributing Member Report Posted June 11, 2025 Thanks Quote
