I got into wood turning awhile ago and got to thinking if there was a way to make some leather blanks.   Finally got around to trying the last couple of weeks.
The bottle stopper blank is glued up 2”x2” scraps, clamped, then drilled with a 1” forstner bit so I could glue in a wood dowel.   The dowel was drilled and a threaded insert put in.
The pen was made by cutting 1”x1” squares a punching a 3/8” hole in each    Then it was simply a matter of a ton of CA glue, stacking the squares on a 3/8” brass tube and clamping for a few days.  Same concept as a stacked leather handle.
The leather turns pretty well.    For those that turn I found a really sharp 3/8” bowl gouge did the trick.   Sanded to 400 grit, burnished and finished with CA glue.
Also found time to stitch up a quick passport wallet for an upcoming trip.
Edited by Mark Peters
Thats how Barry King makes his maul handles as well.
Looks nice. Well done:thumbsup:
Sweet stopper nice work, Which pen kit is that? I have tried to cast some leather blanks a couple times, did not fair well, lol
Are you on any of the pen/blank groups? I don't recall seeing your name.
Nate - it’s an Artisan Indigo from Craft Supply USA.    I don’t belong to any of the pen forums.
I thought about casting it, then I stumbled across a video of a guy that did the punch/glue/stack method.
The stopper is glued up with contact cement - it wasn’t as solid as I wanted, thus the dowel.   I don’t think the pen would have held up with contact cement.     The CA glue was a mess, but it really stiffened things up.   Also, I have a bunch of Horween russet strip scrap which I used.   I think that made a big difference.
Thats why I haven't seen that kit , don't shop that site often , I'll see if exotic has it , need to order a bunch of kits anyways.
CA can make a mess just finishing, lol
These look great!
Hey Mark, love the finished product!
What is CA glue?
What is CA glue?
CA is short for Cyanoacrylate , or super glue, there a few companies that make it with different properties for turners, mainly used as a finish on pens.
Good deal. Thank you!
CA will stick to wet wood, while white or yellow glue won’t.   It’s better for attaching glue blocks on green wood blanks.  It also fills cracks/voids and as mentioned above can be used as a finish.
Very very cool. I especially like the pen.
handmade, wellmade !
  • CFM
try mixing super glue and baking powder
it makes a hard plastic that you can turn in your lathe
I make them out of used range brass
here is a 8mm x 6.5x55 mm pen
