circular holes or holes cut out - is there a difference?
Hey Fred et al.
I think the consensus is that I should be using diamond shaped chisels to stitch watch straps, but I just prefer straight stitches.  I have to admit that when I first started using the diamond shaped punches I have, I was just starting out and I found that I wasn't as consistent with making sure the needle went through the leather the same way, so that is probably part of this.  I think my stitching and marking is a lot better now, but still prefer straight stitches.
The thread to hole size is something I didn't know in such a quantitative way, so I very much appreciate that.  I am using Tiger thread, which I think is flat thread, waxed...and have 0.6, 0.8 and 1.0mm size in most of my colors.
I was trying to think back on my experience with the first set of round dent punches and I remember that it was hard to get them out of the leather.  I even tried putting the teeth in the watch beforehand.  I think the KS punches should be better made and slide in and out more easily.  As far as sharpening them, how would you do that on a round chisel?  Is it just using a fine grit sandpaper on them and going around them?
Neil
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
I don't think that is the consensus at all. I think that the consensus is that you should use a tool which makes slits rather than circular holes, but maybe I am reading it wrong.
The slits could be at an angle, or straight in line, whichever you prefer.
nick
Edited by wizard of tragacanth
Nick
I don't know what you are thinking of when you think of 'diamond' shaped holes.
The diamond shape has been long proven to be about the best hole for straight stitching. The shape allows the thread to be sewn close but the holes are unlikely to tear out
Here is a run of holes made with my pliers
As you can see they are in a straight line, thus the sewing will be as well.
Hey all.
I think I was getting some type of zig zag when I was stitching using that type of punch...probably bad technique when I started...  I guess the holes - when they are just circular - are more likely to tear out than if in diamond shape?
I went ahead and ordered the KS Blade punch set...  I guess we'll see.  I'll experiment with a scrap piece and see if I can achieve straight stitches using both tools...  Will report back.  Hopefully will have the new chisels by the weekend.
Best,
Neil
My understanding is that the angled slits allow more stitches per inch, but also give the thread more "meat" to grab, meaning the stitches are less likely to tear out through the leather. For a small size project, like a watch band, this may be important. The angled slits also mean the holes are smaller in size, so you don't need bigger thread to 'fill' the hole. So the stitches per inch and the thread size are the two variables, rather than having to account for the hole size, also.
Round holes are different -- to punch them out removes a bit more leather, and they can't be placed as close together as the angled slits or else  you get a postage-stamp perforation effect. (I see that many commercial kits use round holes -- I don't know if it's because it's easier for a machine to do that when cutting out the pieces of the kit, or because it's easier hand stitching for the beginner who is the market for the kits.)
I vaguely remember reading somewhere that the diamond shaped awl (which is paralleled in shape by pricking irons and stitching chisels) pushes the leather fibers apart, whereas the round punch cuts through them. (I suspect that in reality they all cut through at least some number of fibers, but the round hole would cut more) Imagine a piece of woven cloth, where you push a needle between the fibers, leaving them intact, or cutting a tiny round hole, breaking some of the threads, thereby weakening the structure. I can't verify that this is actually what happens in leather, though, so I am merely sharing this as a possibility.
If you are using the diamond shaped holes, or the traditional angled slits from an awl / pricking iron / stitching chisel, it is possible to get a "straight" stitch. You basically have to know how to correctly do the angled stitch, and then not do those things. It's not BAD technique, if that's the look you want!
The angled stitch has historical precedent -- it's a marker of hand-sewn saddle stitching, the way it was done for many years. Machines can't do that -- they do a straight lock stitch.  In the end, it really is up to you and how you want your stitches to look.
DJole, thank you very much for the lengthy response.  I'm definitely very new and appreciate all the information and perspective.
I chose this style of punch so that I'm not cutting out a hole, but making a hole instead (pushing the fibers apart as you said) - similar to a traditional chisel (angled slits).  I prefer a wider hole distance (I chose 5.4mm hole spacing) so hopefully that means less of a chance of the thread tearing through a hole.
When I mentioned that I thought my technique was bad it was because I was getting inconsistent stitching patterns.  I don't have an issue with a traditional stitch pattern - it's just not what I want for my watch straps.  That could always change...
Best,
Neil
Pricking irons and diamond awls are the traditional method and predate stitching “chisels” that blow a hole all the way through the work. As an experiment, you should try lightly laying out your stitches with the tool you have now, and make the holes with a diamond awl- one of the cheapo ones from Tandy would do, as long as you sharpen and polish it. You can make holes at any angle you like and see how it affects the appearance of the stitches. I use pricking irons and wheels for layout, but when I’m sewing, I’m just looking for a center: the angle is determined by how I’m holding the awl.
Best,
Neil
You're welcome. There's so MUCH information hidden away on this board that sometimes it's hard for a new person to locate it without sifting through hundreds of conversations over years of posting!
Your reasoning for the punch style makes sense.
Have you had problems with thread tearing through holes before, so you want the holes a bit wider apart?  Under normal use, the holes shouldn't tear. I have a watch strap I made years ago (first one I ever tried...I'll never show it because it's UGLY!), but it shows no signs of the holes tearing through. Instead, I can see wear on the threads.
Perhaps when you are sewing it, you are pulling too tight? I've done that a couple times... learned quickly to watch my tension.
Watch straps use a lighter, thinner leather than many projects do, so I can see how that could be a concern.
What you state about inconsistent stitching patterns is the basic struggle of beginners and hand stitching! It takes time and effort and concentration to keep one needle up and one down, cross one over the other, pull up with one and down with the other...for EVERY SINGLE STITCH! Repeat hundreds of time for big projects!
Then you realize that 5 stitches back you messed up, and you have to pull stitches out to redo that one...grrr...  and then when you pierce the one thread with the needle...grrr... Heh!
It takes concentration and a fair amount of practice to get into the smooth rhythm that people like Nigel Armitage shows in his expert instructional videos on hand stitching.
At any rate, if you (and any customers) like the round hole stitching, then it's a matter of preference or style, and therefore not wrong! (There are even people who use a drill press with a very small drill bit to make stitching holes, because they find it easier.)
The baseball strap you posted a photo above is a great idea -- I have been kicking around the idea of doing a wallet using basketball leather.
I just started making straps but no, no problems tearing of leather.  I just like a chunkier look.  I like other straps I have with tighter stitch spacing, but for a chunkier look - larger thread and larger hole spacing is what I prefer.  I had thought of using a stitching wheel for spacing and a diamond shaped awl, but thought I'd get inconsistent hole shapes...  I do think that when I was stitching before, I wasn't pulling through the thread with each hand properly.  I hadn't discovered Nigel or Ian's videos yet.  Seeking a tighter hole idea is due to when I pull the thread through a hole, the thread wasn't immediately tight, until I had stitched another hole, which tightened the hole before it...  I think with a smaller hole, the threads would be tighter initially....
I've heard of using a drill press for the stitching and buckle holes, but I don't have a drill press so it's not an option at this point.  I think a lot of people who do leatherwork also work with wood, so they have a lot of the bigger tools that can be used for both.  I'm scrapping for space in my office while trying not to get divorced in the process.
If you find any basketball leather please forward on the source.  Rocky Mountain leather has been out of it and baseball leather for a while now....last I checked anyway.  Working with gloves is fun once you figure out what parts you can use and what you can't use.  I've got another glove incoming today.  I'll post some pics when I'm done with it.
Best,
Neil
