Members Reader Posted December 11, 2019 Members Report Posted December 11, 2019 Could anyone confirm that this is a pfaff 1243 with roller presser ? I suppose it could be a 1244 twin needle Quote
Members Constabulary Posted December 12, 2019 Members Report Posted December 12, 2019 I can see the roller foot flipped aside but cannot tell from the pic if it has a double needle but when I look at the Pfaff website the latest 1243 is a single needle machine with roller foot. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members DanishMan Posted December 12, 2019 Members Report Posted December 12, 2019 To me it looks to be a PFAFF 483. Cheers Danishman Quote
Members shoepatcher Posted December 12, 2019 Members Report Posted December 12, 2019 Yep Pfaff 483. glenn Quote
Members Reader Posted December 12, 2019 Author Members Report Posted December 12, 2019 9 hours ago, Constabulary said: I can see the roller foot flipped aside but cannot tell from the pic if it has a double needle but when I look at the Pfaff website the latest 1243 is a single needle machine with roller foot. Thank you for the feedback. I am hoping that this will be appropriate for light leather sewing and maybe belts and bags that are not too heavy. Quote
Members DanishMan Posted December 12, 2019 Members Report Posted December 12, 2019 I guess, it should work fine for that. Quote
Members Reader Posted December 12, 2019 Author Members Report Posted December 12, 2019 Well it turns out it is a Pfaff 441-R-755-03-900-51-BL. The owner used to sew shoe uppers on it, as well as belts. It has automatic thread cutting, I dont know then if it can be changed to back stitch a few stitches before it cuts the thread... I am uncertain whether I should buy it along with a Singer 29K71 I am going to buy from the person. Quote
Members dikman Posted December 12, 2019 Members Report Posted December 12, 2019 Does it have reverse? I can't see a reverse lever, and I would think that you could disable/remove the thread cutter anyway. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Reader Posted December 12, 2019 Author Members Report Posted December 12, 2019 I did not see a reverse lever. I had thought it may be able to reverse using the foot pedal... and at first when I asked the owner he said yes, then no, that pressing the heel down on the lever cuts the thread. He is 76 years old and despite using the machine didn't know much about what can be changed. Quote
Members Constabulary Posted December 13, 2019 Members Report Posted December 13, 2019 (edited) i do not see a reverse lever. Be careful with these old QUICK or EFKA Motors - they great when running but a pain when they stop working. They are no longer supported AFAIK and if you can get support it may be very expensive. Also make sure the motor runs on the voltage you have at home. It is wheel feed machine for shoe uppers so make sure you can adjust the stitch length you need for your products. A lot of wheel feed machines have a rather short stitch length like 2 - 3.5mm. Honestly - I would not buy it if you don´t want to sew shoe uppers. Edited December 13, 2019 by Constabulary Edited from m (meters) to mm (milimeters) Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
