Members Gymnast Posted December 29, 2019 Members Report Posted December 29, 2019 This is a general question, that relates to a more "normal" sewing machines with ordinary drop feet (not walking foot). Most people with some knowledge of sewing machines know about, that the timing of the hook in relation to the needle is important. But the timing of the feed dog are not an issue in the domestic sewing maschine service manuals, that I have seen. I have checked the five sewing machines i got, and they all have a similar timing of the feed dog, and it seems to me that the timing is about 30 degrees late. I think that the designers of sewing machines must have a reason for that, I just like to know why. For domestic sewing machines, there may be some jobs of soft fabrics of high thickness, that a user may like to use the machine for. But this seems not made possible by the chosen timing. I made this video about the issue. I hope someone here may have an answer to the question - why the normal feed dog timing is like that? The cover picture of the video shows the measured position of the feed dog of my Singer 201k. Quote Sewing Machines in Detail, YouTube channel
CowboyBob Posted December 29, 2019 Report Posted December 29, 2019 On the 66 machine in the video the feed dog is adjusted too high.I would lower the height,you should also be able to adjust the feed cam alittle to keep it from feeding as the needle goes in the leather.The 201 machine with the style of hook in it is most suited to keep using lightweight thread & sew what it was designed for.The best models to modify for sewing leather are the Singer 15 class,they have an adjustable feed cam & oscillating hooks like the Singer 31-15 & will take the # 69 nylon better than the 66&201 will. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gymnast Posted December 29, 2019 Author Members Report Posted December 29, 2019 1 hour ago, CowboyBob said: you should also be able to adjust the feed cam alittle to keep it from feeding as the needle goes in the leather Thanks for your answer. I do not think, that it is possible in an easy way to adjust the feed dog timing of the Singer 66 "just a Little". If you see how I adjusted the 201 in the video, you got the same kind of grove in the shaft for the pinol lock screw on the Singer 66 (I suppose the Singer 15 got the same). That means, that if you just do a little advance of timing, the pinol will move the eccendric part back into the factory timing again. To avoid that I think you need to advance the timing at least about 25 degrees. But I guess this will be in order too, unless I should look out for something I do not know about yet. Quote Sewing Machines in Detail, YouTube channel
Moderator Wizcrafts Posted December 29, 2019 Moderator Report Posted December 29, 2019 This is fascinating from a theoretical viewpoint, but begs the question: why are you trying to force domestic sewing machines meant to thin cloth to sew 6mm of leather? It makes no sense unless you simply cannot find an affordable industrial sewing machine that allows full calibration of the feed components. This topic reminds me about some past discussions of portable walking foot machines that were built to sew sail cloth and boat upholstery. Owners were trying all kinds of hacks to get them to sew over 1/4 inch (6mm) of leather with #138 or larger thread and had very mixed (mostly bad) results. Those machines were not built with that work in mind. The same goes for the Singer 66 and 201. Singer's engineers designed them for household repairs to cloth garments, some of which were stretchy, and they are good at doing that. They made better, stronger and more adjustable commercial machines for heavy duty sewing into thick materials and leather. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members nylonRigging Posted December 30, 2019 Members Report Posted December 30, 2019 You tuned it to your specific needs . You now advanced feed dogs, and you slow-speed stroke the needle plunge thew thicker materials . now with your new tune-up . For my curiosity, what I would like to see .. Try sewing with lighter thread and using lightweight fabric with 'speed ' on a straight run stitching, like the machine was built for . . Quote
Moderator Wizcrafts Posted December 30, 2019 Moderator Report Posted December 30, 2019 The feed motion shaft could have another channel cut for securing the offset feed timing. I think that the current feed dog motion is best suited to stretchy cloth, not hard materials. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gymnast Posted December 30, 2019 Author Members Report Posted December 30, 2019 (edited) 11 hours ago, nylonRigging said: For my curiosity, what I would like to see .. Try sewing with lighter thread and using lightweight fabric with 'speed ' on a straight run stitching, like the machine was built for . I will try that. 11 hours ago, Wizcrafts said: The feed motion shaft could have another channel cut for securing the offset feed timing. Yes, it is a possibility, but I consider it to be a rather costly operation in time and effort. 11 hours ago, Wizcrafts said: I think that the current feed dog motion is best suited to stretchy cloth, not hard materials. I am not quite sure of the history of garments here and how early stretchy garments were produced in large quantities. I know that in the past 40 years much more cloth are made of stretchy fabrics. The Singer 66 I got came from factory in 1930 and the design goes further back. It do have this late timing of feed dogs anyway. I think, that a normal streight stitch machine is not that good for stretchy fabrics. Zig zag or double needle is better. And some computer machines make special patterns. I guess that sergers are common to be used for stretchy fabrics today. I got this link with the information, that a fashion designer started to use jersey in 1924: https://www.fulgar.com/eng/insights/jersey-fabrics Edited December 30, 2019 by Gymnast Quote Sewing Machines in Detail, YouTube channel
Members Constabulary Posted December 30, 2019 Members Report Posted December 30, 2019 Really? Once again domestic sewing machine sciences? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted December 30, 2019 Report Posted December 30, 2019 22 hours ago, Gymnast said: Thanks for your answer. I do not think, that it is possible in an easy way to adjust the feed dog timing of the Singer 66 "just a Little". If you see how I adjusted the 201 in the video, you got the same kind of grove in the shaft for the pinol lock screw on the Singer 66 (I suppose the Singer 15 got the same). That means, that if you just do a little advance of timing, the pinol will move the eccendric part back into the factory timing again. To avoid that I think you need to advance the timing at least about 25 degrees. But I guess this will be in order too, unless I should look out for something I do not know about yet. Just go past the groove,I've done it before,as long as the screw is tight it doesn't need to be in the groove. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Gymnast Posted December 30, 2019 Author Members Report Posted December 30, 2019 (edited) 36 minutes ago, CowboyBob said: Just go past the groove,I've done it before,as long as the screw is tight it doesn't need to be in the groove. Thanks Bob. Thats exsactly what I did with the Singer 201. I checked the Singer 237, and it do not have this possibility of adjustment, because the excentrics for the feed dog stroke and the hook movement is a part of the steel shaft it self. So not all machines can be adjusted for that. 13 hours ago, nylonRigging said: For my curiosity, what I would like to see .. Try sewing with lighter thread and using lightweight fabric with 'speed ' on a straight run stitching, like the machine was built for . I tried to sew two kinds of garment with my Singer 201 with and without the forwarded timing of the feed dogs. I was not able to see a change in stitch quality. But I saw a significant change in the required tension from the top tensioner to get a ballanced stitch: When you look at the timing diagram above in thread start, you still do have some movement from the feed dogs after the take up levers is at max. Therefore the movement of the feed dogs are involved in the final stitch forming and tension on the top thread in the fabric. With the changed timing, the feed dogs have finished the movement when the take up lever is at max. Therefore this may require more tension from the tensioner. I guess that the sewing machine designers wanted, that the feed dog movent got involved here in the stitch forming, but I am still not sure why. Edited December 30, 2019 by Gymnast Quote Sewing Machines in Detail, YouTube channel
