toxo Posted January 11, 2020 Report Posted January 11, 2020 Another upside of using a vice or a clamp is that you can leave it to dry which will usually give a better result. Quote
Members Dwight Posted January 11, 2020 Members Report Posted January 11, 2020 5 hours ago, chrisash said: A 2 ton Arbor press is a good way to apply pressure and low cost even the 1/2 ton will do the job I make key fobs like this one, . . . dampen the leather, . . . 1/2 ton arbor press, . . . using a little brass stamp from Hong Kong, . . . Works like a champ. The actual impression is about 7/8 inch tall and about 2 inches long. Trying to stamp that with a hammer, mallet, or maul is a lesson in futility. I lay a 1/4 inch plate steel piece above it, . . . press it down and hold it for about 10 seconds, . . . May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members TargetRockLeather Posted January 11, 2020 Members Report Posted January 11, 2020 18 hours ago, sonataworks said: The leather I attempted to stamp is a 5oz vegtan Eco-Flow dyed and Super Shene treated piece. I don't see this mentioned anywhere so I'll add my two cents. Stamp the leather BEFORE you dye it and certainly before you apply a top coat. You can't properly case the leather if it has been sealed by a top coat. Also I agree with the comments about using an arbor press. They are not expensive and it will make your stamped impression much more crisp and even. Quote http://targetrockleatherworks.com
CFM Hardrada Posted January 11, 2020 CFM Report Posted January 11, 2020 (edited) Just got a 1-ton arbor press, but my results haven't been so consistent: the stamp's impression is kinda uneven. More practice and finesse are needed, I guess. I haven't modified it, by the way, aside from adding a magnet to hold my snaps and rivets setters I'm still using the round-cross-shaped plate. These presses are, if you ask me, indispensable in a leathercraft workshop, and they're half or less the price of Tandy's setter press. Edited January 11, 2020 by Hardrada Quote
