I was asked if I could alter a  couple of belt for a customer that had lost a significant amount of weight. They are caiman so i dont think he wants to get something brand new. The problem is they look machine stitched, so if i cut off the end, then the stitching will start to come out. I dont own a sewing machine and dont even know how to use one, so would it be possible to back-stitch by hand and then hand stitch the new end?
Thanks for the advice
Adam
yes you can. remove the old thread and stitch again by hand in the holes.
Edited by paloma
time does not respect what is done without it
https://tradisign.blogspot.com
https://www.instagram.com/tradisign/
Which end of the belt are you doing this on? I ask because you are showing the tongue.
If possible, I think you want to take it from the buckle end.
You might want to put a drop of super glue in the holes that will be near the cut, to keep the stitches from coming out.
nick
Edited by wizard of tragacanth
Nick
I would take it apart from the buckle end the good part is you can pick the stitching out only to where your going to fold the belt make a new elonggated hole for the buckle then re stitch only the back of the foldthen new screws or whatever to hold the buckle on hope this helps.
Why didn't i think of that! Thats a great idea! Thank you
If he asked me to do it, . . . I would tell him I'm cutting his belt dead center between the hole he uses most, . . . and the buckle end.
I would then add a piece of vegetable tanned leather with his last name on it, . . . with the cut ends very nicely laced together, . . . or a piece of fake caiman, . . . again the cut ends nicely laced together.
That way the front of his belt where most people will notice it, . . . will look like it is the original, . . . and anyone seeing the rear, . . . would have to guess that the belt was originally designed like that.
May God bless,
Dwight
www.dwightsgunleather.com
