Members Bert51 Posted February 2, 2020 Members Report Posted February 2, 2020 Tony, from memory the Adler 205 is the same as my 105 and it has an 8mm stitch in both directions. If you want anything longer you need to settle for a Singer 132K6, my does well over 10mm, but I have only sewn at 10mm, (through ply wood). Bert. Quote
Members TonyGreen3455 Posted February 3, 2020 Author Members Report Posted February 3, 2020 Just now has spoken to my local dealer - for my requirements he suggested Global 9205. Heavyweight machine, will it work with thin leather? Quote
Members Matt S Posted February 3, 2020 Members Report Posted February 3, 2020 1 hour ago, TonyGreen3455 said: Just now has spoken to my local dealer - for my requirements he suggested Global 9205. Heavyweight machine, will it work with thin leather? Chinese copy of the venerable (and now discontinued) Adler 205 so a lot of the advice for that machine would probably apply. However having never played with a Global machine I can't say anything about the quality. For me a 750SPM top speed would be a problem. Quote
Members Bert51 Posted February 3, 2020 Members Report Posted February 3, 2020 I would go and see your local dealer and this time while you are talking have a piece of leather or two, like you will be sewing and try it out. That way you will see what it will do. Bert. Quote
kgg Posted February 3, 2020 Report Posted February 3, 2020 1 hour ago, Bert51 said: I would go and see your local dealer and this time while you are talking have a piece of leather or two, like you will be sewing and try it out. I agree. Since this is going to be a expensive investment go visit dealers with your stuff in hand and sew with the size / type thread you want to use. No one machine is going to do both ends of the sewing / thickness spectrum. I think the machine that was recommended is going to tear the hell out of the thin stuff since your requirement is only for appearance and not structure. There are videos of the difference between the Juki 8700 vs Juki 1181 vs Juki 1541 vs Juki 1508 using the same material and how the 1541 and 1508 destroy the same thin material. The object is to use the right machine with the right needle system for the job otherwise it is like using a sledge hammer to hammer in a finishing nail. Also getting the stitch length perfect every time maybe a chore for awhile since it has the reverse and stitch length on the same lever. Remember buy once, cry once. Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TonyGreen3455 Posted February 3, 2020 Author Members Report Posted February 3, 2020 (edited) 1 hour ago, kgg said: I agree. Since this is going to be a expensive investment go visit dealers with your stuff in hand and sew with the size / type thread you want to use. No one machine is going to do both ends of the sewing / thickness spectrum. I think the machine that was recommended is going to tear the hell out of the thin stuff since your requirement is only for appearance and not structure. There are videos of the difference between the Juki 8700 vs Juki 1181 vs Juki 1541 vs Juki 1508 using the same material and how the 1541 and 1508 destroy the same thin material. The object is to use the right machine with the right needle system for the job otherwise it is like using a sledge hammer to hammer in a finishing nail. Also getting the stitch length perfect every time maybe a chore for awhile since it has the reverse and stitch length on the same lever. Remember buy once, cry once. I remember it is why I'm here and coming to pro guys with newbie questions, just to prevent long crying ) Juki and their clones AFAIK have a jog dial for length regs and reverse pedal. Regarding one machine for everything - you right, different tools for different jobs, but... nowadays who knows what will customer look for tomorrow? Especially if I'm choosing my first machine for leather. Anyway, I booked a visit to my local dealer already, just trying to narrow and finally find the name of my dream ) Can anyone help me to recognize this model of Juki? Edited February 3, 2020 by TonyGreen3455 adding picture Quote
JJN Posted February 3, 2020 Report Posted February 3, 2020 It looks like a Juki LS-341. Odd that the factory label that has the model and serial numbers is missing. It looks the stitch length dial goes to 9+ mm. Quote Ferdco Juki Pro-2000, Juki DNU-1541S, LS-1341, LU-563, DLN-9010A-SH, MO-6714S, Consew 206RB, 206RB-1, Chandler/Bernina 217 6mm w/Cam Reader, Brother LT2-B842-5
kgg Posted February 3, 2020 Report Posted February 3, 2020 1 hour ago, JJN said: It looks like a Juki LS-341 I agree but doesn't Juki 341: 1. usually have the nameplate rivet to the machine which means two holes should be present where the weird square intention is. 2. doesn't look like the normal Juki latch connecting the base to the sewing machine 3. the metal seems to be cut back further towards the main body on the bottom of the cylinder. I would investigate further as if I remember someone in France had a problem with a Pfaff branded machine that wasn't. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
