Moderator Wizcrafts Posted February 13, 2020 Moderator Report Posted February 13, 2020 I have a 29k71 that gets almost 5 to the inch. The feed motion bell crank has a little play in it, Quote
Members Snakeoil Posted February 13, 2020 Author Members Report Posted February 13, 2020 I have another issue with this machine. Two actually, but they may be related. I checked the timing on the machine today and it is a little late. By that I mean the edge of the shuttle carrier is not covering the first third of the needle hole as described in the manual. In adjusting it, I found that there is quite a bit of rotational play in the needle carrier. I'm thinking that either the drive pinion is worn or the screw that holds the carrier to the pinion is loose. I'll be looking into that issue. What may be a related issue is when I use a different shuttle than the previous owner used, the machine sews well until the thread for some reason gets wrapped under the shuttle carrier. I have to remove the needle plate to be able to move it out of the way and cut the thread. With that done, I use tweezers to pull the thread chunk out from under the carrier. It only seems to happen with that shuttle. I like that shuttle better because the tension spring is perfect. The other shuttle has a spring with a razor edge where you work the thread under the spring and it is easy to cut the thread in the process. I compared the shuttles and the appear to be identical and with no difference in wear. I moved my light to the rear, Constabulary. I needed to get at that hole to adjust the timing and figured I might as well move the light while I had it off. Thanks, Rob Quote
Members Snakeoil Posted February 14, 2020 Author Members Report Posted February 14, 2020 Probably should have made the previous post a separate thread. Oh well... Took the cover plate off gear box. Nothing stood out other than the drive pinion for the shuttle carrier was kind of loose in the gear box bore. I see that on the K71 they modified the design to use a replaceable bushing for the drive pinion bearing. But on the K70, the gearbox is simply bored and the pinion runs in that bore. I did find that carrier slop I reported in the previous post is due to a combination of lash between the gear and racks and excessive play for the drive pinion. I was pressed for time so did not take measurements. I'm hoping the drive gear is the wearing component and replacing that will reduce if not eliminate the play. Another option is to simply machine a thin bushing to take up the clearance. Will revisit this. With the shuttle drive out, I found it was packed with oily paste from years of use. The carrier spring had signs of wear as well. I have two spares that came with the machine. When I go back into the box to take measurements and see what can be done to tighten things up, I'll probably replace that spring. I have two needle plates that do not fit this machine. Once has the counterbores for bobbin clearance and the other does not. Both are identical with respect to hole placement and that placement is different than on my K70. The bobbin clearance looks like it is for a large bobbin machine. But the parts diagram I have for K72 machines shows a needle plate that looks like the ones on my K70. Maybe these are from an earlier or later design large bobbin machine. I'd be willing to trade these for K70 parts. They are not unused, but damn close to it. Quote
Members JPFrance Posted October 1, 2024 Members Report Posted October 1, 2024 Hi Snakeoil, Hi Members, I just register to have an account, I am JPFrance, (from France of course!) I am rebuilting a 29K71, and I have discovered the wonderful parts you made as take-up lever adjuster. My question: I have all original adjuster parts, in good conditions, but I ignorate the reassembly procedure, how do you ecalibrate, adjust it ? I am looking for that procedure since long time, without success. All the rest is working well. Many thanks for your help! JPFrance Quote
Members shoepatcher Posted October 1, 2024 Members Report Posted October 1, 2024 Turn the dial it all the way and test it for the amount of take up lift in the lever. Then turn it all the other way and check. This should tell you which end of the scale it for less and greater. Choose somethin in the middle. Singer engineers in their stupid thought over engineered this part so that it it way to complicated to dial it in. The older way was much simpler on the early versions of the 29K58,60,62. None of the clone machines made today use the complicated dial on the later machines. Keep it simple stupid as they say. Anybody needing parts to the more modern take up lever adjustment, I found a source for them. glenn Quote
Members JPFrance Posted October 2, 2024 Members Report Posted October 2, 2024 Hi Glen, Many thanks for your help, and your clear answer! It is my first experience with such machine. Before I was sewing with domestic simple models. It was the last mystere (until today), for me with this machine. I have now to adjust other parameters according the project. I guess I will spend a certain time before sewing correctly. I send you sun and blue sky from Lyon! Have a nice day. Jean-Pierre Quote
