On 2/12/2020 at 5:15 AM, jimi said:
I dont have any setup for binding at the moment but here is the foot and binder that i use, i am no expert at this remember Lol.... And the Pfaff one has been heavily modified by the previous owner:blink:
20200212_110416.jpg.c3c49ee66b179321abf1f371768be168.jpg20200212_110453.thumb.jpg.b0ae2f66fe083ded5981646b1ec569b8.jpg20200212_110500.thumb.jpg.9293d36ece2d7b85c186ca2cf6f756b0.jpg20200212_110519.thumb.jpg.1f8663b44415b88a96578aff89fa82c8.jpg20200212_110534.thumb.jpg.2886f338800abcc6dd8de48ba60e5356.jpg20200212_110800.jpg.a8ea2ca117024166a1070c26c5c40e72.jpg
Hi there! I wanted to let you know I got things going. Made a bracket for the cheap binder I had and I’m good to go.
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
Wow, nice... well you know what they say "necessity is the mother of invention" :Lighten: Lol... your very crafty jeannie, that will keep you going for a while now, at least to get some practice in. As Folker said, the corners are the hard ones because if you don´t get in near to the foot then you end up off the tape on a tight corner, so maybe don´t try it on a bag without trying to do some practice corners first. And also you might need another screw to hold the bracket at the back as the tape could pull the tip in towards the foot?? just a thought...
Edited by jimi
Yes I will practice a lot before I screw up this leather. Do I have it close enough now?(in the pics) or do I need to get closer..or buy a shorter foot? I’m waiting on the binder arm bracket I ordered so these screws are temporary. I will have the y’all bolts Tuesday. I will order a pfaff binder in the next week probably too.
I have just set up the old one so you can see the setup. If you need a parts manual for the 335 let me know, i have it in PDF.
20200216_140515.thumb.jpg.64a4e448f10321ae5fd85badb4276411.jpg20200216_140525.thumb.jpg.4a266852b61d023cc8e11e2448bb7c3b.jpg20200216_140546.jpg.3da4d26009569442bc0a56e92e24643d.jpg20200216_140606.thumb.jpg.377503f35a2c65d63cf4e100c30a38f6.jpg
The closer the binder is set to the needle the better it works on curved items. You probably have to grind down the tip on the inner foot a bit. The Pfaff 335 type binders are designed for this type of machine (I think they are called shell binders). The one you are using (and so do I) are meant for flat bed machines or "unsynchronized" cylinder arm machines. So it requires a bit of tinkering to set them up for synchronized binder machines. If I had found reasonably priced 335 type binder for the tape size and thickness I´m using I would have bought them but they were not available at that time and I´m too much a cheap charlie and don´t wanted to pay high prices for an custom binder so I went the "economic" way and figured it is a good way (in this case). Of course my bracket does not look like factory made but the whole setup work great!
I know I repeat this but when you order a 335 type / shell binder make sure it is designed for the tape thickness you want to use!!!
Sample:
https://www.college-sewing.co.uk/at18c-20mm-x-5mm-x-1-5mm-shell-binder.html
20x5x1.5 means:
  • 20mm tape
  • 5mm mouth width
  • 1.5mm thick tape
Edited by Constabulary
20200216_140515.thumb.jpg.64a4e448f10321ae5fd85badb4276411.jpg20200216_140525.thumb.jpg.4a266852b61d023cc8e11e2448bb7c3b.jpg20200216_140546.jpg.3da4d26009569442bc0a56e92e24643d.jpg20200216_140606.thumb.jpg.377503f35a2c65d63cf4e100c30a38f6.jpg20200216_142601.jpg.f89aef7533f9f52992d191f815c34717.jpg20200216_142729.jpg.cba67156dc5a543777d7ae8f10ee5cc8.jpg20200216_142814.jpg.917d2a4ac75d31f9b9f14fb86e9b41e9.jpg20200216_142858.thumb.jpg.cd50a550850b7fdf15af02c28a9f06be.jpg
Ohps! I went a bit off at the end Lol... i had to wing it by hand as there is no motor on this machine yet....
I think folker does a better job than me ;)
Edited by jimi
Ok thanks! I printed the manual out. I didn’t think the manual would tell me what binder feet to use so I didn’t think to look at it. I will look it over. The bag I’m making has curves so I need it to be able to do that efficiently.
Edited by Northmount
Remove photos to reduce size of post, less time to scroll to new material
Sample:
20x5x1.5 means:
  • 20mm tape
  • 5mm mouth width
  • 1.5mm thick tape
Ok thank you I will make sure. I see some pfaff binder foot sets on eBay. The pfaff binders I only see in China and shipping is over a month...not sure I want to wait that long lol. I will keep hunting.
Would the one you attached a link to work on my machine? If so maybe I need to just go with that one
I meant the parts manual so you could see the type of feet and binders that the 335 type machine uses, they might still be making variations?
Subclass Old C 3.pdf335 H3
Subclass Old C 4.pdf335 H3
Subclass Old C 5.pdf335 H3
Subclass Old C 6.pdf335 H3
Subclass Old C 7.pdf335 H3
Oh ok. I printed that out too.
