Definitely a Redneck set now.
Bert.
I've ordered a 100m roll of tape, can someone tell me the approx. diameter of such a roll, please? I'm making a stand for it and need to know what size to make the base (and no, I'm not using a cake tin lid!).
I realised you have already ordered, but this company is not far from me and I for got them.
https://www.vardhman.com.au/
I have not purchased anything so far, but I shall be in the not to distant future.
Bert.
:lol: That's who I bought it from! Ordered it yesterday and already shipped so prompt service.
But what's the diam. of the roll? I've modified a table clamp with a vertical threaded rod and made a bearing mounted support but I need to know what size to cut the support disk. I should add that I don't have a cake tin lid but I do have a round biscuit tin lid that might do. I might use it just for Brian.:lol:
It all depends on how they supply it. I have actually had it come all loose in a bag once. The lid I use is about 20cm if that helps. A bit wider might be better. What I did with the wood piece under the lid is get it so the height is about level with where it feeds into the prongs on the machine. Being on a heavy wood block enables me to position it where ever I want on the back of the sewing table. To me its a bit like getting a good thread run to the tension discs with the thread, You want nothing to hook up or cause any intermittent tensions as it feeds through the prongs and on into the binder shape thing. Warning some tapes feed way nicer than others and you may want to do some machine alterations in order to get the tape to feed more fully in. I removed the left side of the back foot for a start.
Original in this pic
Now altered below
Now able to get the tape further over another 2mm and it works way better especially when going around curves and corners.
YouTube Channel
Instagram
They are less then 30 min drive from where I live, sadly I have not needed to visit them since I found out they were so close.
Bert.
Pretty drastic alteration, Brian. I'll keep it in mind. The reason I'm using threaded rod for the upright is that I'd already figured that I'd need to make it height-adjustable  to get the best feeding of the tape. I'm on version 2, wasn't quite happy with version 1.
Bert, could be pretty handy having them so close, you could save a bit on shipping.
Edited by dikman
I remembered them after my last buy up on bindings and other bits and pieces that they sell.
I purchased a 5 thread overlocker off some one in the same town and he told me about them, have not been back in town since.
Bert.
