Members mrdabeetle Posted March 20, 2020 Author Members Report Posted March 20, 2020 I opened up the machine and the set screw on the timing shaft has moved a couple of millimeters. (marks can be seen where it has been moved) I moved it back into the deepest mark made by the set screw and tested a scrap of 6oz. veg tan. It stitched perfectly, so I tried stitching the garment leather again and it stitched fine until I got to where the leather is folded over where seams join and it skips stitches again. It isn't birdnesting anymore, but it is skipping stitches. Quote
Members dikman Posted March 20, 2020 Members Report Posted March 20, 2020 Personally, I think that you're asking the poor little machine to do more than it was designed for. Realistically, you're getting into the realms of industrial machines. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Bert51 Posted March 20, 2020 Members Report Posted March 20, 2020 I think you may have reached the limit of your machine, most of us have done it at some time and now it might your time to move to a heavier machine. Sadly they are not cheap and I found the first one hard to justify, but you will be able to sew what you want to. Many great people here will help you if you think you need more information. Bert. Quote
Northmount Posted March 21, 2020 Report Posted March 21, 2020 21 hours ago, mrdabeetle said: It isn't birdnesting anymore, but it is skipping stitches. Thicker seams tends to grab the needle and lift the presser foot on the up-stroke, collapsing the loop so the hook can't grab it. Try increasing the spring compression on the presser foot. Tom Quote
DonInReno Posted March 21, 2020 Report Posted March 21, 2020 I’d agree with others that your machine isn’t up to what you’re asking of it. An older all metal domestic machine out of the 50s, 60s, or 70s can be found in slightly used condition at thrift stores for under $50 that is much more capable. Better yet is an older commercial machine that can be had for almost the same price, but you’ll need to be a little mechanically inclined to get it adjusted - I see one every month that someone inherits or they are tired of and they just want it gone. Quote
