Hi there!
I'm new to Leather crafting and even if i've spent hours and days and weeks learning about the craft before starting my firsts project, i missed this tiny "costly" information..
I started a bag and while making my closing system yesterday i made a mistake that damaged the leather...
I taped the top of the bag to hold a piece, two tiny pieces of the varnished surface were torn off when I removed the adhesive tape, they measure about 4mmx2mm .
What should i do? Maybe glue them back together? If yes, which glue would be suitable? Or maybe do you see a better solution?
Pictures of the damaged surface are attached to this message, i wish someone told me about "Never using tape on leather" before..
Thanks in advance and all the best!
IMG_0772.thumb.jpg.f8f8c776f4d7a7fa9bbbafb8e2b4fb68.jpgIMG_0773-2.thumb.jpg.cbda9b7aba7b4a1b0d2191bcf08d91ff.jpg
Edited by NMendes
The aesthetic aspect is of little concern to me, i am mostly worried about reinforcing the damaged surface to prevent it from widening, what would you do in my situation?
Thanks al!!
Maybe a clear varnish of same sort in the local area?
you could do a couple of tests on any scrap / cut off that you have
Edited by HaloJones
Are we sure that's leather?  In 9 years or so I've seen leather do some funky things.  But I've never seen the grain come off of a full grain piece of leather.  Crack, split, break?  Yes.  I've only seen faux leather do what yours did.  Between that crackled surface and the grey underside, something is not adding up for me.
Thank you for your answers!
@HaloJones : I'm thinking of using natural conditionner like Coconut oil or Beeswax instead of gluing, i'll run some tests today and will let you know!
@ChiefJason : Oh yes it is genuine leather, and not a cheap one.. I bought it from a renown retailer here in Paris who sells "A" quality hides by "Tannerie Haas" (Hermès suppliers), it is a 2,5oz Calf skin and the damage is way less pronounced than what you see in the pictures..
Here is the bag i'm making so you can see how the leather really looks like (still a work in progress) ..
What do you think about my natural conditionner solution?
It looks like metallic finish leather to me, which from my experience, is the least durable, least permanent finish you can get.  I bought a side of silver metallic this winter for a pair of rodeo chaps, and the finish flaked off simply due to the stresses of the building process, no tape involved.  Turning and bending the leather to get it through the sewing machine left silver glitter everywhere.  While that is NOT normal, metallic is still not a very durable finish.  Exercise caution when incorporating it into any project.
The finish is not metallic at all, here is a thread where they talk about the exact same problem :
https://www.vintageleatherjackets.org/threads/tape-damage.1803/
Quote
" This does bring up a very important subject, though. That subject is being careful with any type of adhesives around top grain leather. Depending on how the hide is finished, the top coat can peel off quite easily. I remember several years ago on one of the earlier versions of VLJ, a member mentioned going to a work/social function with his wife and they were issued adhesive name tags at the door.
The guy put on the tag without a second thought. A while later after leaving the function, the guy removed the nametag off of his A-2 jacket (a Real McCoys Dubow if I remember correctly). Unfortunately he immediately noticed that the outer color layer peeled off noticeably!
Leather jacket are tough articles of clothing, but that can be damaged with adhesives or sharp objects with surprising ease."
It seems like a common issue..
Try a little bit of pva glue, it might hold it while keeping it flexible.   Maybe a tiny bit modgepodge on top to help seal it.
Just guessing from my limited experience of this type of leather, but I think that’s the approach I’d take first.
These surfaces can be difficult to manage when working with them.
“Equality?   Political correctness gone mad, I tell you, gone mad!!!!    Next they'll be wanting the vote!!!!! :crazy:“.
Anger and intolerance are the enemy of correct understanding
Thank you for your answer Lumpen!
Like some said, if the piece came off so easily, the leather is not durable at all..
So i'll buy a more sturdy leather hide (horse hide), it will coast me more but way less than using a weak piece..
Thank you again all for your advices!
In 30 years of working with leather (only 20 properly) I've only seen this on fabric backed PVC. The material was sold to us as 'real leather' and top ££ paid. A simple burn test proved it was PVC
as for a glue, I would use UHU or Bostick
