8 hours ago, AzShooter said:
Great looking sheath. Whoever it's for will be very happy.
Thanks - appreciate your comments!
Cowboy 4500, Consew 206RB-4
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
Made another case today using economy grade elk - had to trim a lot of loose skin and patch a few holes.  I think for large projects I will stick with the better grade hides from now on.  Still have to install hoeprn button and tie.  Anybody have a good source in the USA for elk or deer horn to make buttons?
20 hours ago, garypl said:
Made another rifle case this afternoon using a piece of 3-4 oz Italian cowhide.  Took me a little less than 2 hours start to finish.
I am getting tooo old I think. 2 hours for me to do the frills maybe. How do you do them @garypl?
YouTube Channel
Instagram
I just lay out a piece of leather and take a straight edge and rotary cutter and cut one at a time.  Takes me 15-20 minutes to cut two pieces of fringe 10” wide.
Thanks Garry, I am still getting used to the idea of using a rotary cutter on leather as yet. I have only used in on the fabric face masks as yet which was the reason I bought it. I will have to give it a go as that sounds like a good idea for that sort of cutting.
YouTube Channel
Instagram
Bob Stelmack
Desert Leathercraft LLC
Former Editor of the, RawHide Gazette, for the Puget Sound Leather Artisans Co-Op,  25 years of doing it was enough...
Thanks Bob. I started pla+printing something along that line about 5 hours ago. My printer will only allow a 7" x 7" jig but I may give it a go later on my laser as well. I will pop some more pictures in the morning as it will be printing for a couple of more hours yet. I am going for 4.5mm (.177 of an inch)spacing for this one at the moment. I am going for 4mm height and solid with a 5% outward lead in for the knife and a .5mm gap at the bottom. That is for a quicker line up in the slot. More info tomorrow-
YouTube Channel
Instagram
Yep she worked and better than I thought possible. To clean up the print from any connecting strands I thought I would cut down into a bit of stiff veg and this below is what I got.I didn't think I was pushing all that hard.
A little push and WOW
A light shade or bottle cover who knows-
Back to cutting a fringe now
Bit hard to see at this stage
Still took a couple of minutes to do though first time and all:wub:
Gary if want to give me whatever spacing you would prefer I will do you up an stl file if you like or you could try this size if that works for you.
Regards Brian
YouTube Channel
Instagram
Thant makes it look easy, I avoid anything with a fringe.
I think you might find a good market for those.
Bert.
