Was thinking about starting to airbrush my leather wallets,want to get fades.
Seen Weaver Leather has a airbrush kit but I'm not sure if it's worth it?
Don't know much about airbrushing and wanted to hear from the pros
a. you'll need a good compressor
b. a gravity feed airbrush will need less free-air and lower air pressure from a compressor
c. on a gravity feed a/b you want as large a cup as you can get, some a/b have interchangeable cups and you can buy bigger ones
d. needle size; a 0.2mm will be good for fine work, 0.5mm will give faster coverage over a larger area. get an a/b from a maker who supplies different sizes of needle sets.
  • CFM
I just ordered a 2 gallon Air compressor from harbor freight fortress brand I believe. I had a small compressor built for air brush but it didn't have a tank so it wasn't very smooth at laying down paint. Gonna give it a try myself but now i'm having a blast just painting with it. I have a pasche vl  it was given to me but it comes with three size needles and tips and sure seems to work well for the limited time I've been playing with it. Haven't tried any dyes through it yet however.
I have an air brush from Hobby Lobby but haven't used it yet.  Adams leather works made a spray booth out of a chest box fan and some cheap air filters.  Just put the filters on the suction fan and spray your work infront of the filter.
Andrews leather uses his airbrush to apply Resoline finish.
Scootch
For the last few weeks I have been airbrushing dye exclusively.  I'm using an airbrush set from harbor freight.  I'm happy, I had to pick up a few things, a quick connector with a regulator, larger bottles that I could store the dye in and an inline secondary moisture trap. All and all another 20-30 $ US. But the set only cost me $90. For compressor, hose,1 brush and a c,leaner pot. If your going to do more than one color I'd suggest another brush but you can get them from harbor freight for $20.00 a pop. They are all syphon feed, meaning the dye is pulled from the bottle that sits under the airbrush. Dubble action, meaning you can adjust the amount of paint as you paint. I am not a pro. But I have used it a lot as of late. I don't know what Weaver's set is like but I'm sure it costs more than the one I have.  Look in to it.
Cool I'll have to check it out.
I have a whole sale account,so the weaver one to me is only $50 shipped. It's gravity feed,dual action..looks tiny but think I'ma just give it a go..don't know much about all the connectors,etc so kinda want a all in 1 kit..will def be doing multiple colors so I'll have to learn that
1. When you get the airbrush, check any hose supplied with it. It might be just a basic hose. Replace it with a fabric braided rubber hose. It really helps with the airflow
2. when sorting out the connectors for a/b to hose and hose to compressor get a quick release set for the a/b to hose end. A q/r is handy for changing a/b quickly, or just taking off the one for cleaning and packing away
3. get a set of a/b cleaning brushes, only cost you about $3 but worth it for really cleaning the a/b
  • 2 months later...
The one you are looking at from Weaver I bought a while ago.  It never really worked very good from the start.  Inconsistant spray pattern.  Now it just spits a splattered spray all over.  Not usable at all now.  I would save my money and get something better.
a. check the needle tip. rub it down with some fine grade wet & dry paper. it may not be needle sharp, it may have a slight kink in the very tip
b. clean out the nozzle cups, there maybe a speck in there.
It doesn't take much to make a spray brush go wonky.
Really sucks that cleaning an airbrush is part of weekly shop maintenance. An end of use simple blowout vs. a full brake down and clean. And I thought it was supposed to save me a lot of time!:wub:
(In truth AB save lots of time. You can do some great effects, even delve into AB art. Drying time is about 5 to 7 minutes if that much. On smaller  projects it's dry before I do a simple blow out of the AB. More consistent color throughout a piece. The color I use is so much closer to the color advertised, no more darkening a project beyond recognition trying to even out the color.  And I end up using less dye.)
All and all I call it a win.
Edited by Grumpymann
