What size hole should I use with .8 mm thread?
Thank you
0.5 to 0.8 mm, depending on your thread. I use flat profile thread and its best in 0.5 / 0.6 mm holes
Thank you guys very much!
Sorry, I must qualify that.
I like 0.6 mm when its a single thread doing a running stitch but 1.2 mm approx if its a double thread in a saddle stitch
If its a normal round thread, 0.6 mm to 0.8 mm hole for a single thread. The thread will squeeze down a bit and the leather will expand a wee bit so the thread will fill the hole. Approx 1.5 to 2 x for double thread in a saddle stitch
It will take more of a pull to take the thread through the smaller hole but if its kept well waxed it'll slip through well enough
Good information.  Thank you
  • 1 month later...
On 7/12/2020 at 10:41 AM, jimi said:
Hi there,  there are 4 sizes,Check out the chart. https://www.custompartnet.com/tap-size-chart
That chart is for screw threads.
