Members jcuk Posted July 30, 2020 Members Report Posted July 30, 2020 All you need to know is here, https://leatherworker.net/forum/topic/36221-how-to-make-a-strop-for-knives/ Funny enough i have just made myself another strop using pretty much the same method only i used Tandys saddle skirting leather managed to run 4'' width through my pull through splitter and no did not give myself a hernia, just did not try to take to much off in one go, made it a double sided strop.Only i loaded mine the traditional way for saddlers in the uk Hope this helps JCUK Quote
CFM Frodo Posted July 30, 2020 CFM Report Posted July 30, 2020 5 hours ago, Alaisiagae said: At the risk of me sounding like a slow, stupid child: Did you harden your leather with hot water, @Frodo ? @fredk How long does it take for the leather to dry after being soaked in water (and soaked for how long?)? Is there a leather thickness you think is good - 6 to 7oz? Thinner? I did buy some neatsfoot oil (100% pure, but I think I overpaid for it, oops), so I've got that now. I do not soak my leather in hot water or cold water in making my strop i simply glue a piece of leather on a board , works for me Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members mike02130 Posted July 30, 2020 Members Report Posted July 30, 2020 (edited) There's the easy way and then the difficult way. One is better than the other. Best advice is to read and figure it out then ask questions with some knowledge so you will better understand what you are asking and what folks are recommending. That way you won't have to "risk" anything. Then you can answer the next persons' question about strops. If you really want some good schooling check out some blade or razor forums. They seem to know whats best. That's where I learned. The link "jcuk" posted above is an excellent one. Hell, send me ten bucks and I'll mail you a 2" x 6" compressed horse butt strop. But no more questions about strops for one week. Consider my snarkiness as a trade off for giving you the strop. Edited July 30, 2020 by mike02130 added last paragraph. Quote @mike02130 Instagram
Members Danne Posted August 11, 2020 Members Report Posted August 11, 2020 (edited) I'm certainly not expert on making strops, and I don't think anyone have to be an expert. So let's start with the question, what do you want from a strop? 1. A surface that is relatively flat 2. Something that isn't to soft (It will round over your edge very quick if it's too soft. I bought some wood with an even finished (planed and sanded? woodworking terminology is not my thing) I used it to build a stitching horse and a leather strop. And I used 1mm leather with a flat a relatively stiff surface, glued it with contact cement and use a roller from the middle and out. Cut the excess leather off and used some neatsfoot oil and green compound (chrome oxide) Is this the correct way to do a strop? Yes, ALL the ways that work good to strop your knives are the correct ways. Edited August 11, 2020 by Danne Quote
CFM Frodo Posted August 11, 2020 CFM Report Posted August 11, 2020 Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members philg9 Posted August 12, 2020 Members Report Posted August 12, 2020 For my strops, the only leather that does the job is panel hide, glue it grain siode down so the underside is facing up, dont need to boil it etc, cut to size of your board, glue it down, I glue a bit on both sides, one soide I smear jewellers rouge for cutting and de burring, then the othersid eof the strop is left as is, I use the plain side after I have done a blade on the jewellers rouge for the finla polish. If ther eis burrs on a blade, I will use a fine wet and dry paper first, then go onto the jewellers rouge then the plain side. Quote
Members DanC Posted August 19, 2020 Members Report Posted August 19, 2020 For my strop - I used thinner leather on a wood board (with handle). The reason is simple (and hinted at above - without realizing it). It won't "give" under stropping pressure. The thinner the better (4oz +-) works just fine. The reason for thin over thick is that thick allows the leather to compress (soak it so it will shrink and tighten up) as you pull the knife over it, giving you a more rounded profile edge. Thin on a board prevents the round over effect to a great extent That's what works for me. P.S. I also use an Oak board that is charged to strop on. It doesn't give at all. Quote
