Members Wykoni Posted September 13, 2020 Members Report Posted September 13, 2020 Has anyone tried using a wax finish to your vegetable tanned leather project. I am thinking of oiling the leather and once tried using some form of soft wax finish. Like maybe wood finish wax. I know it will soften the leather and in some cases that’s not a bad deal. Quote
Members Dwight Posted September 13, 2020 Members Report Posted September 13, 2020 I use a concoction of 50 % by weight . . . pure bees wax and 50% by weight . . . neats foot oil. Not the compound . . . the real OIL. I put it in a jar . . . suspend the jar in a pan of hot water . . . it melts the beeswax . . . they get melded together . . . Rub it on the leather . . . polish . . . you'll like it. It's a 100+ yr old recipe . . . add more oil if you want it a bit softer. I've made and use both. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Wykoni Posted September 13, 2020 Author Members Report Posted September 13, 2020 2 hours ago, Dwight said: I use a concoction of 50 % by weight . . . pure bees wax and 50% by weight . . . neats foot oil. Not the compound . . . the real OIL. I put it in a jar . . . suspend the jar in a pan of hot water . . . it melts the beeswax . . . they get melded together . . . Rub it on the leather . . . polish . . . you'll like it. It's a 100+ yr old recipe . . . add more oil if you want it a bit softer. I've made and use both. May God bless, Dwight Got some of both, thanks Quote
Members billybopp Posted September 13, 2020 Members Report Posted September 13, 2020 11 hours ago, Dwight said: I use a concoction of 50 % by weight . . . pure bees wax and 50% by weight . . . neats foot oil. Not the compound . . . the real OIL. I put it in a jar . . . suspend the jar in a pan of hot water . . . it melts the beeswax . . . they get melded together . . . Rub it on the leather . . . polish . . . you'll like it. It's a 100+ yr old recipe . . . add more oil if you want it a bit softer. I've made and use both. May God bless, Dwight I've been using @Dwight's recipe for some time now, and love it. If I want it a little softer, I put in a little more NFO, and if I want it a little firmer I put in a little more wax. I also add just a few drops of Eucalyptus or Tea Tree Oil just for the scent. Most of the time, I pour it into foil cupcake cups to let it cool into a cake. Other times, I pour into "lipstick" containers that I got from eBay, and give a tube away with the things I make. - Bill Quote
Members paloma Posted September 13, 2020 Members Report Posted September 13, 2020 13 hours ago, Dwight said: I use a concoction of 50 % by weight . . . pure bees wax and 50% by weight . . . neats foot oil. Not the compound . . . the real OIL. I put it in a jar . . . suspend the jar in a pan of hot water . . . it melts the beeswax . . . they get melded together . . . Rub it on the leather . . . polish . . . you'll like it. It's a 100+ yr old recipe . . . add more oil if you want it a bit softer. I've made and use both. May God bless, Dwight I use this recipe too with 60% percent of neast foot oil,it's the best for me. Quote time does not respect what is done without it https://tradisign.blogspot.com https://www.instagram.com/tradisign/
Members ScottWolf Posted September 13, 2020 Members Report Posted September 13, 2020 14 hours ago, Wykoni said: Has anyone tried using a wax finish to your vegetable tanned leather project. I am thinking of oiling the leather and once tried using some form of soft wax finish. Like maybe wood finish wax. I know it will soften the leather and in some cases that’s not a bad deal. I use an all natural wax based conditioner/finish that I make myself for my projects. I posted a step by step recipe , along with ratios , etc on how to make it that will work with pretty much all the common ingredients used/found in leather working products. You can tinker around with it or just follow the recipe as is. Here is the link: Quote
Members Wykoni Posted September 13, 2020 Author Members Report Posted September 13, 2020 Thanks all, tried 50/50 but felt it was too firm so added more oil turning it into a paste. I preferred it that way. Quote
Members ScottWolf Posted September 13, 2020 Members Report Posted September 13, 2020 30 minutes ago, Wykoni said: Thanks all, tried 50/50 but felt it was too firm so added more oil turning it into a paste. I preferred it that way. Follow the ratios in the recipe and you'll get to an end product to your liking quicker. A 1:2 ratio ( 1 wax, 2 oil) will get you to a semi firm product. If you go 1:3 you will have a very soft butter. The more oil you add to the ratio, the softer it will continue to get but after about 1:5 ratio it's usually too soft and melts very quickly to the touch. Quote
