Members Grosent Posted June 11, 2021 Members Report Posted June 11, 2021 (edited) On 6/9/2021 at 10:44 PM, RockyAussie said: putting a spacer under the plate that the stitch length adjustment rod goes through. Interesting! @RockyAussie Would you possibly be able to share a photo of where you put the spacer? Edited June 11, 2021 by Grosent Quote
RockyAussie Posted June 12, 2021 Report Posted June 12, 2021 9 hours ago, Grosent said: Interesting! @RockyAussie Would you possibly be able to share a photo of where you put the spacer? I think the machine I did this on along time ago has been packed away but I can show you where on some other machines if that is of any help. As your model pulls downward to go into reverse it would need the spacer at the top. On the machines in these pictures the forward stitch has the rod at the bottom and reverse is at the top. Note that on this 441 style machine that the plate that the stitching adjustment rod goes through is wider at the top to reduce the stitch length in reverse. It is common on these machines for people to further increase this measurement with a wedge to get a better reverse stitch length. On this old 331 Pfaff I have taken the plate on the front off all together to obtain a longer stitch length. This involved a LOT of checking first to be sure that the dog foot length etc would not go longer than the hole would allow. This allowed quite a lot wider stitch length than standard and I have had no issues in over 20 years with it. In this 335 style machine where I am pointing I could put in a spacer under this plate to reduce the forward length stitch in comparison to the reverse stitch length. By spacer I mean something on the one end to angle the plate. Some people use a washer. Myself I would print up a plate once I determined exactly how much angle it needed. A spring under the screw would be great if there were room as that would allow for variations if need be. Note that at the top in this case also has a wider section to correct the stitch length in reverse. Now this Adler below has one interesting feature in that it has an adjustable stopper to set which stops the forward stitching from being able to go longer than it is set to. Now if the forward stitch is limited by this stopper and the rod adjustment nut is turned out further then the reverse stitch length is free to still have a longer stitch in reverse depending on how far the nut is opened out. Note: on this machine the reverse plate gets smaller at the top instead of wider. (Just something to think about) I hope that this is of some help. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
