Members RAMPER Posted October 6, 2020 Members Report Posted October 6, 2020 I am confused about the needle I need for a LU-563. I have attached the manual. Does the LU-563 ONLY use #23 needles? And what is the difference between DNX 17 and DNX 1? I thought the 563 was just a LARGE bobbin 562, so they should use the same needles Quote
Members Pintodeluxe Posted October 6, 2020 Members Report Posted October 6, 2020 No, it's recommending a #23 needle for a subclass 3 of the LU-563. You can use 135x17 needles sizes 18 to 23. Or 135x16 needles for leather. Quote
Members RAMPER Posted October 7, 2020 Author Members Report Posted October 7, 2020 OK, I see that now, thanks Quote
DonInReno Posted October 10, 2020 Report Posted October 10, 2020 You can use any size needle - some industrials manuals just list a 23 as the suggested size - I suppose to signify it’s ability to sew with heavier thread. Quote
Moderator Wizcrafts Posted October 10, 2020 Moderator Report Posted October 10, 2020 The maximum needle size is determined by one or more factors, including: the diameter of the hole in the feed dog or throat plate and the position of the hook in relation to the scarf in the needle and how far it can be moved and remain in time. Those are physical limits. Additionally, there are thread handling limits that apply to any given sewing machine. Some machines have stronger or weaker take-up levers and crank shafts in the head. Some, if not most upholstery grade walking foot machines are built with an upper thread size limit of #138 (T-135) bonded thread, which has a breaking strength of 22 pounds. If that machine is threaded with #138 thread on top and in the bobbin, that is its safe design limit. Coincidentally, that thread combination calls for a #23 (Metric 160) needle. While those machines will operate with #138 thread using a #23 needle, they are happier running #69 or 92 thread with a #18 or 19 needle, respectively. All of the stresses are reduced with thinner thread and needles. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Rachal Posted January 20, 2021 Members Report Posted January 20, 2021 Jumping in here because I'm having some difficulty with my 563. I can't figure out needles aswell. Trying to sew binding on carpet and the machine is sewing it, but having a hard time. Using #69 thread and I'm assuming 135x16 needle. It came with a full pack that size but I'm unsure. Any one know the proper size I should be using? Quote
DonInReno Posted January 21, 2021 Report Posted January 21, 2021 4 hours ago, Rachal said: Jumping in here because I'm having some difficulty with my 563. I can't figure out needles aswell. Trying to sew binding on carpet and the machine is sewing it, but having a hard time. Using #69 thread and I'm assuming 135x16 needle. It came with a full pack that size but I'm unsure. Any one know the proper size I should be using? Rachael, “135x16” is the type of needle, but that is not the size of eye in the needle. The “16” seems to throw people off, but just remember it’s nothing to do with eye size. Also keep in mind “135x16” is for leather - for carpet or fabric you want to use “135x17”. For #69 you’ll want an 18 size needle. It’s definitely confusing at first because needles often have a lot of other information that clouds the waters. A pack of needles will look something like the photo below - you just want to make sure it states the correct size - size 18 for your thread - and that it states 135x17. All the other numbers are what this kind of needle is referred to by other manufacturers, so don’t be concerned with them. I hope this helps. Quote
Members Rachal Posted January 21, 2021 Members Report Posted January 21, 2021 Thank you very much! Quote
Members Gregg From Keystone Sewing Posted January 22, 2021 Members Report Posted January 22, 2021 (edited) DNX1, that's more like a bag closer needle. Some of the older Juki books did contain errors, for sure their old LG-158 book. Edited January 22, 2021 by Gregg From Keystone Sewing Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Millerville Posted December 13, 2022 Members Report Posted December 13, 2022 Sorry to bump an old thread. Does it matter if the needles are ball point or regular point? I am looking to use 207 thread in a 563 with leather. Quote
