Members dikman Posted November 29, 2020 Members Report Posted November 29, 2020 Many have used treadmill motors to drive small lathes and they appear to work well but Don makes a good point about why it might be problematical on a sewing machine. Given that servos are relatively inexpensive and are a simple plug-and-play it seems like the logical way to go. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Pintodeluxe Posted November 30, 2020 Members Report Posted November 30, 2020 On 11/25/2020 at 5:29 PM, RWL2 said: Was there any downside to greasing the cork friction plate? Did it slip when sewing through tough material after being greased? How greasy did you make it? Is it worth greasing the brake to make it easier to turn the handwheel? About a teaspoon of grease on the friction plate. It just makes it slip a little smoother, but didn't cause unwanted slipping. I've never tried grease on the brake. Quote
Members RWL2 Posted November 30, 2020 Author Members Report Posted November 30, 2020 Thanks Pintodeluxe. I haven't looked carefully yet at how the clutch is removed from the end of the motor. I suspect it won't be hard to remove since they were intended to be used in production facilities where time is money, but I've never taken one apart before. Quote
Members Constabulary Posted November 30, 2020 Members Report Posted November 30, 2020 (edited) You most of the time have clutch motors with approx 1400 /1500 rpm or 2400 / 2800 rpm. How many RPM has your motor if more than 1500 I would replace it no matter what. Edited November 30, 2020 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members RWL2 Posted November 30, 2020 Author Members Report Posted November 30, 2020 1750 RPM Singe phase. Speed reducer with 2" to 8" pulley and the drive pulley to handwheel pulley is about 2" to 3". I didn't put my tachometer on it recently to see what the speed of the machine is, but It was somewhere around 400 RPM. The maximum speed isn't a problem. It's getting the slow speed when coming to the end of a seam when you want to place the needle just so. I may eventually get a servo motor, but it's not in the immediate future. Quote
Members Constabulary Posted November 30, 2020 Members Report Posted November 30, 2020 okay so a 2" to 8" pulley reduction can do the trick then. But I would replace it with a servo. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members RWL2 Posted December 1, 2020 Author Members Report Posted December 1, 2020 I greased the cork clutch pad today. I wish they'd build these things with fasters with a hex head rather than a phillips head. I got the three retaining screws out, but they were tight and I worried about stripping the heads. Photos of the clutch for anyone who's never seen the insides. The first shows two of the three screws that holds the clutch on. The second shows a thin layer of rust on the steel clutch plate. The third is a closeup of the cork clutch pad and the fourth photo shows the greased pad next to the SuperLube that I used. Quote
DonInReno Posted December 2, 2020 Report Posted December 2, 2020 That rust will give you fits - hopefully it sanded off easily. Quote
Members RWL2 Posted December 2, 2020 Author Members Report Posted December 2, 2020 12 hours ago, DonInReno said: That rust will give you fits - hopefully it sanded off easily. It was just surface rust. I hit it with a little steel wool and it came right off. I think the previous owner had the table in her garage. Now it's in my cellar which is relatively climate controlled and dry. Quote
Members sandmanred Posted December 2, 2020 Members Report Posted December 2, 2020 Did it work? Quote Have Consew 255RB-3, Pfaff 545 H4, Chandler 217, Pfaff 138 and Merrow 60W. Had a Singer 132K6, Singer 78-3 Consew 28, Consew 18, Singer 31-15 and regret selling each and every one of them
