Members kinger79 Posted January 5, 2021 Members Report Posted January 5, 2021 Hi all, I have a couple of questions about getting parts for my Mitsubishi CU865. This is a machine that was sewing heavy felt filters before I got it and I am still trying to get it tuned to do an acceptable job with leather. If my research is correct, these are really designed more as a binding machine, so the bottom feed dog only goes back and forth? I really like the machine, though it was not my first choice, the price was right, it was local, and it has a programable servo and eps (which were on my "must have" list). My biggest issue right now is that the bottom feed dog has really aggressive teeth and it leaves tracks that are unacceptable for me. I understand that any machine will leave some tracks, but these leave actual teeth marks. I am looking for a smooth feed dog or a hack to reduce the marking. I have already loosened the presser foot tensions as much as I can. From what I can gather, this machine is very similar to a Pfaff 335 or some of the older necchi machines. I am having trouble finding parts for this model of machine. Will the pfaff 335 parts interchange for the most part, or is there a good source to get Mitsubishi parts in the US? Any help or tips are much appreciated! Thanks Andrew Quote
Members ryano Posted January 5, 2021 Members Report Posted January 5, 2021 Have you looked through this thread yet? https://leatherworker.net/forum/topic/84911-looking-for-cylinder-arm-for-leatherbag-making-necchi-840-100/ Quote
Members kinger79 Posted January 5, 2021 Author Members Report Posted January 5, 2021 yeah I did... good stuff Quote
Members SARK9 Posted January 6, 2021 Members Report Posted January 6, 2021 3 hours ago, kinger79 said: I am having trouble finding parts for this model of machine. Which parts? -DC Quote
Members kinger79 Posted January 7, 2021 Author Members Report Posted January 7, 2021 On 1/5/2021 at 7:32 PM, SARK9 said: Which parts? -DC Specifically a thread guide for the top. the knurled for the thread take up spring, and a new feed dog. In general though they are kind of tough to locate mitsu parts for. Quote
Members SARK9 Posted January 7, 2021 Members Report Posted January 7, 2021 (edited) As far as I know, the "old casting" Pfaff 335 feed dogs and needle plates interchange with the CU-865....they are all over Ebay etc. You need to know if your's has the parts for the synchro binder or the regular feed setup. The presser feet are the ubiquitous Singer 111W type walking foot style. Zillions. My upper thread guide is factory stock but looks different than the one in the parts books....mine is a simple straight rod with the typical 90 degree offset holes for the thread to pass through....just a short section of threads on the lower end secured with a jam nut. The knurled nut.....ummm...here's the thread control ass'by. Maybe pick a number? -DC Edited January 7, 2021 by SARK9 Quote
Members kaibcn Posted April 18, 2021 Members Report Posted April 18, 2021 Hi all, hope everyone’s well. hi kinger79, came across your post, I have the same machine. have you come across an instruction manual of this particular model? greetings from Barcelona/Spain Kai Quote
Members Tolom Posted August 3, 2021 Members Report Posted August 3, 2021 (edited) Boa noite, estou precisando do manual de instrução da mitsubishi cu 865, na internet só achei o catalogo de peças, alguém pode passar uma dica como conseguir: Good evening, I need the instruction manual for the mitsubishi cu 865, on the internet I only found the parts catalogue, can anyone give me a tip on how to get it: Edited October 4, 2023 by Northmount Translation added Quote
Members Zeek039 Posted January 27, 2022 Members Report Posted January 27, 2022 I have the same machine and where do you find parts for it like a new roating hook? Quote
Members chisel Posted February 27, 2022 Members Report Posted February 27, 2022 On 1/27/2022 at 8:15 AM, Zeek039 said: I have the same machine and where do you find parts for it like a new roating hook? eBay is one source. There is a small bobbin version of the CU-865 and also a larger one that uses an M bobbin. On the model plate under CU-865 it should have a 12 or 22. 12 is the small bobbin version, 22 is the larger. If you need Koban or Hirose hook part numbers to help with your search, let me know. Quote
Members Tolom Posted October 4, 2023 Members Report Posted October 4, 2023 (edited) | Bom dia ,como faço para comprar um calcador vivo de viés ,da máquina mitsubishi c u 865. | Good morning, how do I buy a bias presser foot, for the mitsubishi c u 865 machine. Edited October 4, 2023 by Northmount added English translation Quote
Members NolyGil Posted April 5, 2024 Members Report Posted April 5, 2024 (edited) El 10/04/2023 a las 13:23, Tolom dijo: | Bom dia, como faço para comprar un calcador vivo de viés, da máquina mitsubishi cu 865. | Buenos días, como compro un prensatelas al bies, para la máquina mitsubishi cu 865. Edited April 5, 2024 by NolyGil Quote
Members NolyGil Posted April 5, 2024 Members Report Posted April 5, 2024 On 10/4/2023 at 1:23 PM, Tolom said: | Bom dia ,como faço para comprar um calcador vivo de viés ,da máquina mitsubishi c u 865. | Good morning, how do I buy a bias presser foot, for the mitsubishi c u 865 machine. Yo también estoy buscando. Comparto lo que he encontrado, que no es mucho pero al menos es algo ... Quote
Members NolyGil Posted April 5, 2024 Members Report Posted April 5, 2024 Hola a todos, estoy tratando de conseguir todos los complementos que pueda para mi Mitsubishi CU865. ¿Alguien sabe cómo se llama esta pieza que hace tope para que la costura quede paralela al borde? Gracias. Quote
Moderator Wizcrafts Posted April 5, 2024 Moderator Report Posted April 5, 2024 3 hours ago, NolyGil said: Hola a todos, estoy tratando de conseguir todos los complementos que pueda para mi Mitsubishi CU865. ¿Alguien sabe cómo se llama esta pieza que hace tope para que la costura quede paralela al borde? Gracias. Translation: Hi everyone, I'm trying to get as many add-ons as I can for my Mitsubishi CU865. Does anyone know what this piece is called that stops so that the seam is parallel to the edge? Thank you. @NolyGil; Ese dispositivo se llama "guía de borde". In English: That device is called an "edge guide." Quote
Members NolyGil Posted April 6, 2024 Members Report Posted April 6, 2024 20 hours ago, Wizcrafts said: @NolyGil; Ese dispositivo se llama "guía de borde". In English: That device is called an "edge guide." gracias Quote
Moderator Wizcrafts Posted April 6, 2024 Moderator Report Posted April 6, 2024 4 hours ago, NolyGil said: gracias Da nada! La mayoría de las guías de borde tienen rodillos que corren contra el borde del trabajo. El rodillo le permite moverse sin ser arrastrado hacia atrás por la fricción contra una simple pieza de acero. Quote
Members NolyGil Posted April 9, 2024 Members Report Posted April 9, 2024 On 4/6/2024 at 5:20 PM, Wizcrafts said: Da nada! La mayoría de las guías de borde tienen rodillos que corren contra el borde del trabajo. El rodillo le permite moverse sin ser arrastrado hacia atrás por la fricción contra una simple pieza de acero. Qué buena idea, no lo había pensado. La verdad es que siempre he cosido a pulso, pero reconozco que con ese complemento me facilitaría bastantes labores. Quote
Moderator Wizcrafts Posted April 10, 2024 Moderator Report Posted April 10, 2024 12 hours ago, NolyGil said: Qué buena idea, no lo había pensado. La verdad es que siempre he cosido a pulso, pero reconozco que con ese complemento me facilitaría bastantes labores. Estoy de acuerdo. Normalmente uso una guía de borde desplegable en mi grapadora pesada Cowboy cuando necesito coser a lo largo de los bordes de un proyecto. Si está en el camino en las curvas, lo levanto hasta que esa área haya pasado, luego lo dejo caer según sea necesario. Quote
Members NolyGil Posted November 19, 2024 Members Report Posted November 19, 2024 On 10/4/2024 at 6:41, Wizcrafts said: Estoy de acuerdo. Normalmente uso una guía de borde desplegable en mi grapadora pesada Cowboy cuando necesito coser a lo largo de los bordes de un proyecto. Si está en el camino en las curvas, lo levanto hasta que esa área haya pasado, luego lo dejo caer según sea necesario. Uy sí, las curvas hay que hacerlas con cuidado para que queden bonitas. Quote
