Sneak peek: Acrylic flatbed attachment for Juki LS-341 class machines
7 hours ago, Constabulary said:
seems to be available
https://uwe.store/collections/featured-items/products/ut341-flatbed-for-juki-ls-341-class-machines
Could be IP geoblocking if you can´t see the shop.
At the top of the page   -Shop closed for good as of 12/20/2022. Thank you and farewell.
Edited by CowboyBob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
I have overlooked this :whistle:
Too early for you?Get somemore coffee!:rofl:
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
On 1/9/2023 at 3:08 PM, nlopezdearenosa said:
Hi!! Do you still have these available? I just adopted Darla the Juki LS 341, but your shop seems closed. Desperate here !
@nlopezdearenosa  Take a look at this alternative for sale on Etsy:
https://www.etsy.com/listing/1222743460/mini-topstitching-table
I’ve not used it myself, but it has good reviews and looks like a very nice flatbed attachment.
Uwe (pronounced "OOH-vuh" )
Links: Videos
  • 2 years later...
Has anyone found an alternative table attachment since both links listed in this thread are no longer active?  I have a Juki LS-341N.  The shop I bought the machine from only had some huge, bulky, hard to put on/take off option so I passed.  Looking for a nice sleek option like these.
Thanks.
Edited by CBaker
If you are a DIY guy you can make one your self. I once made one for my Singer 45D91 but the Idea was stolen from LW member UWE.
Just an idea. 😉
Recent Relics Design on Etsy has some nice looking options that work for the ls-341. I do not have first hand experience though.
https://www.etsy.com/listing/1628261312/folded-edge-cylinder-arm-table-read-the?ref=shop_home_feat_2&bes=1&sts=1&logging_key=df14ac46157a5699adef0f95481e19144bc0bbad%3A1628261312
I got an aluminum table for my Juki LS-341 from RecentRelics on Etsy. It’s a very nice table and with some upgrade modifications, it’s rock solid and takes seconds to install or remove with a single thumb screw.
I was not a fan of the 3D-printed bits that came with the table attachment, so I replaced the one for the thumb screw with a small aluminum plate, and the arm wedges with a custom-molded J.B. Weld SteelStik saddle. The round magnetic tray insert for needles or clips can be found at most hardware stores.
J.B. Weld is a steel reinforced epoxy putty for making repairs to metal parts. It’s a miracle in stick form. You tear off a part of the stick and knead it to activate it. You can file, drill, cut just like metal when it’s hardened. I used half a stick on either side of the arm.
Here’s how the table attachment arrived, including the 3D printed parts (You can’t see the arm wedges on the underside of the table.)
Here are few pics of my modified table attachment:
This is the J.B. Weld SteelStik saddle. I wrapped the arm with kitchen plastic cling wrap, then in stalled the table and pressed half a stick of J.B. Weld in the gap on either side of the arm. It sticks really well to the aluminum table (but not the plastic wrap) and it conforms perfectly to the arm, paint/casting dimples and all. I filed some edges down a bit by hand.
Edited by Uwe
Links: Videos
That's pretty sweet!
  • 1 month later...
The single thumb screw sounds great!
My plexiglass table I still need to do some filing on to get it to sit completely flush. But now I know what to do if I file too far...Steel Stik 😺
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
