Members swhoelefp69 Posted February 20, 2021 Members Report Posted February 20, 2021 (edited) Hi everyone! 2nd post, and very new to leatherwork. I'm working on a 2nd mask, and looking for some guidance on applying Gel Antique to specific areas of the mask, vs. wiping it over the entire mask. I've watched several videos on applying Gel Anqitue, and they all show the apply liberally, wipe off excess. I've asked the original designer of the mask in the pic below how to achieve the effect. He mentioned that after painting a base white Angelus coat, and adding black angelus to the nose, he applies black Gel Antique to specific areas, and wipes off excess. With everything I've seen with adding Gel Antique, wiping off excess would add more black to areas not meant to have the gel. I'm guessing I would darken the mask trying to wipe off the gel, and it would make the overall mask more black (not wanted), vs white, which is what i'm going for like the pic. Can anyone recommend how to add Gel Antique in specific areas, and wipe off, without dragging the gel into areas that are not meant to have the gel added? Is spot antiquing something that is done? Would I just add it in specific areas, and wipe it off with a wool dauber, vs using a cloth? How could i ever add it around the teeth, and keep the teeth mainly white? I appreciate any help/guidance from the talented members here Edited February 20, 2021 by swhoelefp69 add pic Quote
Members SaintJoy18 Posted February 20, 2021 Members Report Posted February 20, 2021 I've never used the gel antique, but maybe using a q-tip to apply small amounts in the areas you want it then wiping up the excess with a firmly held cloth (like block dying) might work? Quote
CFM chuck123wapati Posted February 20, 2021 CFM Report Posted February 20, 2021 use a resist in the areas you dont want the dye. I use eco sheeen it is a finish for leather work once it is on no dyes will absorb. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM Frodo Posted February 20, 2021 CFM Report Posted February 20, 2021 You must use a resist, Here I painted the leaves and stems with resist, waited till the next day and antiqued it Quote Singer 66, Chi Chi Patcher, Rex 26-188, singer 29k62 , 2-needles D.C.F.M
Members swhoelefp69 Posted February 21, 2021 Author Members Report Posted February 21, 2021 If I've painted the entire project with white Angelus paint, won't that act as a resist? I've read a few posts on here from folks who say it works like a resist. Then when I apply the antique, it will remain in the tooled areas to give depth, and when wiped off, I should still have the white background - though, I have also read it may discolor the acrylic paint somewhat. Quote
CFM chuck123wapati Posted February 21, 2021 CFM Report Posted February 21, 2021 On 2/21/2021 at 12:14 PM, swhoelefp69 said: If I've painted the entire project with white Angelus paint, won't that act as a resist? I've read a few posts on here from folks who say it works like a resist. Then when I apply the antique, it will remain in the tooled areas to give depth, and when wiped off, I should still have the white background - though, I have also read it may discolor the acrylic paint somewhat. Expand test it on a piece of scrap. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Sheilajeanne Posted February 21, 2021 Members Report Posted February 21, 2021 Yes, test first! I've often been very disappointed with the results of antiquing, even when I used two coats of resist! Quote
Members battlemunky Posted February 21, 2021 Members Report Posted February 21, 2021 You may even want to try to "paint" it on with a q-tip. Dip the q-tip in some gel antique and then wipe off most of it onto a paper towel and use the residue left on the q-tip to get in those areas around the base of the teeth and in the cracks. It'll get the goo where you want it and make getting it off the places you don't want it pretty easy. This is just a guess though, I'd test it for sure. Quote
Members Outfitr Posted February 22, 2021 Members Report Posted February 22, 2021 I think if you just want to target some areas I would use a resist then a paste antique. Quote
Members swhoelefp69 Posted February 24, 2021 Author Members Report Posted February 24, 2021 thanks everyone! great advice, and I will certainly use it all Quote
