Members JamesRiley Posted February 23, 2021 Members Report Posted February 23, 2021 (edited) I miscalculated the number of holes I needed and pre-stabbed some needle holes in a piece of leather. Is there a magic trick for making those disappear, or at least become less obvious? I'll be dark staining the whole piece. They aren't really located where decorative stamping would go. Thanks for any tips. Edited February 23, 2021 by JamesRiley Quote
Contributing Member fredk Posted February 23, 2021 Contributing Member Report Posted February 23, 2021 1.are they along the line you'll be sewing? they'll go awol under saddle stitching 2. you can use a modelling tool to burnish the leather around them to press the surrounding leather in towards the hole to make it less visible. A little bit of water dropped into the hole will help make the hole close up as well Quote
Members jcuk Posted February 23, 2021 Members Report Posted February 23, 2021 (edited) After you dark stain it and not sure if you are going to use any finish after staining it, rub Bees wax over it, won't disappear but will make it less obvious. Hope this helps JCUK Edited February 23, 2021 by jcuk Quote
toxo Posted February 23, 2021 Report Posted February 23, 2021 Use some rough sandpaper on a piece of the same leather, collect the dust and plug the hole using some dry clear glue. Quote
Members JamesRiley Posted February 23, 2021 Author Members Report Posted February 23, 2021 Thanks, folks. I will give those ideas a shot. Quote
Members Rahere Posted February 23, 2021 Members Report Posted February 23, 2021 If nothing else works, sew into that area as if it's what was supposed to happen in the first place, even if it's not actually doing anything. Quote
rktaylor Posted February 23, 2021 Report Posted February 23, 2021 Depending on the size of the hole and leather weight, you may be able to plug it with a leather 'thread'. Use a strip of leather from a stitch groover to thread needle. Pull it through the hole and trim it flush. I've used this on a saddle skirt and it blended in really well. You could find the mistake hole if you knew where to look. Randy Quote
