On 4/27/2021 at 3:11 AM, Klara said:
I think that I just possibly might leave well-set rivets uncovered on the inside, meaning I'd use them on an unpadded collar. Maybe.
If the set is clean and smooth, and there's nothing exposed that would cause irritation... sure!  Rivet caps have a nice finish.
On 4/27/2021 at 6:48 AM, Alexis1234 said:
I use prong spots on collars I've made with a liner because I think it looks nicer. However,  on horse harness they will put spots on parts that aren't lined. The prongs are just bent over  and flattened really well.
I have learned (since starting this thread a year ago...) that 2-prong spots tend to have stronger and longer prongs (claws?) than 4-prong spots.  They are the only type that will penetrate collar-thick leather.  I have also (since then) tried setting metal and rhinestone spots:
image.jpeg.13718de5edfa8a28532a6b53e9eb836b.jpegGEMAGIC PEARL Studs Size 20 4.5mm 200 Pcs
You are spot (ha! :lol:) on.
I am by no means an expert, but at least I understand now what you're describing.
Machine setting forces prong points into the leather due to the shape of the die.  Hand setting creates prongs that "are just bent over and flattened really well" ...at least for 2-prongs.  4-prong spots are thinner and don't flatten as well when set by hand (in my oh-so-humble opinion) —they're designed more for fabric and thinner materials, and to be set with a die.
As for the templates: I make my own.
You are far more talented than I can ever hope to be...  Chris Mantz has some nice templates for spots and rhinestones.  Here's the website I couldn't remember before:
https://www.tacktemplates.com/online-store/Spot-Setting-Template-p81157850
Edited by ButtonLady
Made images smaller.
Sewing Machines:  Juki DNU-1541 and waaay too many home machines and sergers...
Button Machines:  Osborne, Wade, Defiance, Maxant, Handy Jr. #1 and #20, Fasnap PM5 (and too many dies to count)
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
I would never put metal prongs against any animal so all my harness and collars etc is lined as is most of what I've seen . The only evidence of no lining is some which has been botched by an amateur or foreign made.
Thank you for weighing in!  This is a fascinating subject —it's the reason I joined the forum.
Here's a dog collar from Karma Collars:
Zion Leather Dog Collar, Collars, Karma Collars, Karma Collars: Custom Leather Dog Collars
https://karmacollars.com/collections/designer-bling-custom-handmade-leather-dog-collars/products/zion
Prongs are exposed but points are buried in the leather... only possible with a die.  Machine-set, I assume —is there such a thing as a hand-set die that does this?  For those just learning (like me), here's an example of a machine die:
Die For Preset Rhinestones (Bedazzler)
https://allstarco.com/en/setting-tools/6831-die-for-preset-rhinestones-bedazzler.html#/206-size-5mm
The raised center of the left (bottom) die pushes the prongs upward into the material.  I tried a machine die from a Chinese manufacturer (Dot-Gas), and all it did was flatten the prongs.  Really disappointing (sizing was off, too... different story).
So... on to horse tack.
I revisited the Biothane tack link from last year:
https://www.twohorsetack.com/images/product/icon/29_1_.jpg
https://www.twohorsetack.com/p-29-bling-beta-biothane-western-bridle-with-full-browband.aspx
Rhinestone spots on the reins are exposed/points buried, but presumably the rest is lined —because there is visible stitching?  Is it possible to set spots in the top layer and then stitch THAT CLOSE to them?  Same thing with leather, too.
This example was clearly set after sewing because spots are covering the stitching... but presumably it's lined (?):
Bling for Equestrian | Dreamtime Creations
https://www.dreamtimecreations.com/page/bling-for-equestrian/
There's a LOT I don't know about this.
I love all the bling things! Keep posting, you have my attention. I want to do some of this kind of work. Thank you for sharing. I have a few tools, but will be gathering more!
I know... right?  So... shiny... :wub:  It is a journey of discovery —glad to have you along. :)
Missed the edit window:
It's possible these "spots" are actually rivets added after stitching.  Maybe even Chicago screws —can they be called "conchos" if they're that small?  Either way, I think the biggest issue would be punching a neat, well-placed pilot hole.
1 hour ago, fredk said:
You can get domed head ready-rivets. I use them when I want the rivet to be more decorative
Oooh... pretty!
Any problems with not crushing the domed end?
2 hours ago, ButtonLady said:
Oooh... pretty!
No problems. One uses a rod/bar setter with a dome shape in the end. I use a bar one size larger than the rivet, eg for a 6mm rivet head I use a 7mm setter
Thank you Fred! I'll be getting some of these!:)
