I know I'm beating a dead horse, here...but I promise, I really have searched the forums (and youtube) on this topic, and tried to solve this seemingly common issue myself.
The issue I'm having is that there seems to not be enough tension on the top thread.   As in, I can see the top thread, on the bottom of the workpiece.  I'll go into what I'm sewing, and with what, and then what I've already tried.
The machine is an 'original' Consew 206rb (the plate with the model # on it only says "206rb", no "-1" or "-5").  It was purchased used, obviously, but had been serviced, and seems to have seen very little use in it's past.  There's almost zero wear at all on the bed of the machine.  Bearings were re-packed, timing checked.  I have no way of verifying that the guy who did this servicing knew exactly what he was doing, but I also have no reason to doubt him.  I'm using Schmetz needles, which I only just realized as I'm writing this, are NOT diamond/chisel point.  I've been using 135x17 serv7 needles in sizes 21, and 22, with #138 nylon thread.  (I'm going to scream if this whole time the issue has been that they aren't chisel-point needles).
I'm sewing mostly light-medium weight leather, generally a 3-4oz veg tan with another thin (1.5-2.5oz) garment leather on top of that.  I've also done some sewing with 3oz chap leathers.
With my stitches, the best result I seem to be able to get is to have the top thread slightly peeking through the bottom side on nearly every stitch.   I'm also getting a pretty ugly bunching of thread on the under/back side any time I do a backstitch...though changing the feed dog seems to have helped some with that.  I've also noticed that the presser feet will not raise higher than about 3/8" (and that's with the hand lever.  It barely lifts 1/4" with the knee lever)... when the internet seems to agree that the 'max capacity' for the 206rb is around 9/16", and trying to actually sew anything near this 3/8" thickness results in a HUGE mess of loose top threads on the back side.
I have checked (and adjusted) the bobbin case tension.  It passes the "bobbin drop test".  I have watched so many videos on threading the machine I think I could do it in my sleep at this point.  I've checked, and re-threaded, and checked, and re-threaded, so. many. times.  The top tensioner is so tight that even with the presser feet up/knee lever pushed, it's still hard to pull the thread through.  Tightening it any further results in broken thread.  Loosening the bobbin case spring any further results in risking the leaf spring getting caught up in the hook.
I have changed needles.  I have changed the feed dog. I have change the presser feet.  I've oiled everything.  I've tried different bobbins.  I've tried a new bobbin case.  I'm just...really at a loss at this point.
Is it the needles?  Is it possible the machine is just set up/timed for much smaller thread?  The guy I bought it from said he'd never used anything in any of his machines that was larger than #69 thread.
...I think that's all I know to include in this post.  Please, take pity on me.  I'm still very much in the learning phase with industrial sewing machines in general.  And thanks in advance for any help.
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I had a similar problem with my 206RB-4 in that I suddenly couldn't pull up the thread even with the top tension extremely tight  I was using 138 thread top and bottom.  It had been sewing fine and suddenly the problem started.
With the bobbin case out of the machine, the bobbin thread came out easily but as soon as I inserted the case back into the machine, I could hardly pull the bobbin thread out.  I tried every adjustment possible and nothing helped so I bought a new, genuine Consew bobbin case and voila, everything works again!
Does your thread pull off the bobbin easily when your holding the case outside the machine?  If yes, install the bobbin case and check if it still pulls out easily.  If it is extremely tight you might have a defective bobbin case.  My old case was not a genuine Consew case and by briefly inspecting it, I could see no visible difference between the old case and the new, Consew case.  But it has worked fine since I replaced the case.
Hope this help.
Gary
Cowboy 4500, Consew 206RB-4
When getting an upholstery class machine set up and running, use 92 weight thread and a #20 needle.  Chisel point / leather needles will result in a cleaner exit hole, but round point are fine for initial testing.
Realize that 138 thread is the limit for this machine.  To sew 138 with leather, you'll need a #23 needle.
Please post pictures of your thread path from the thread stand all the way to the needle.
Please switch to 92 weight thread and a #20 needle for testing.  Adjust tension for that setup and report back.
Being a owner of these machines since 1976 I have some experience.
One The thread release works on both knee lift and hand release and is adjusted by a screw on the right side of the tension disk slightly to the back.  The release should be adjusted at the very top so tension is not affected.
Two  The amount of lift is adjusted by a set screw behind the machine below the crank lever (my term) You will need to take the front cover off to to adjust the up and down movement on the rod.  Simple but difficult to explain
Three  You can now adjust the feed lever on the back left to balance the the needle and foot feed.  The right lever with the thumb screw adjusts the lifting height for various thickness.
Four Bobbin case irregularity is caused by a bad case or a too tightly wound bobbin that expands  and rubs against bobbin case
If you don't understand any of this let's tackle each issue and I will probably get you through this. This is one of the best machines for performance and durability.
Hope this help.
Gary
Gary - The bobbin thread pulls up and pulls through just fine in my case.  It definitely pulls through -much- easier than the top thread.
I don't have any 92 weight thread to switch to.  I can try with some 69.
I'll try to attach some pictures.  If my code doesn't work, they're here at this imgur post: Threading Consew 206rb
<img src="https://i.imgur.com/coCdPcQ.jpg" alt="206rb thread post" width="4032" height="1908">
<img src="https://i.imgur.com/g5MGTLS.jpg" alt="206rb top thread guid" width="4032" height="1908">
<img src="https://i.imgur.com/GfHqnaY.jpg" alt="206rb tension discs" width="1908" height="4032">
<img src="https://i.imgur.com/N4OKDko.jpg" alt="206rb take up lever" width="1908" height="4032">
<img src="https://i.imgur.com/VhL7dyM.jpg" alt="206rb lower thread guides" width="1908" height="4032">
<img src="https://i.imgur.com/50PdlFN.jpg" alt="206rb needle threading" width="4032" height="1908">
Edited by Lokahi
Thanks for these tips.  Most of it seems straight forward to me.  I'll see if I can figure out #2 when looking at the machine itself.  #4 doesn't seem to be my issue.  The bobbin case is brand new and the bobbin thread pulls up and feeds smoothly... is there anything else that might be causing my tension issue?
Don’t give up on it. They are really good machines. I have and use two of them. One set up with 135 and one with 69.
Edited by klutes
Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy  bell skiver,  Beilers embossing machine
Alright. I switched my bobbin thread to 69, and rethreaded top around this little post.. Am now getting much better results.
Edited by Lokahi
  • 1 month later...
Ok, I had a paragraph about what I thought was a threading problem.  Well, as soon as I clicked "Submit" and looked at your pictures again, I realized the only problem is with my eye sight.  Nice first post of mine...
Edited by JohnInAZ
Need new eye glasses LOL
