On 5/18/2021 at 7:22 AM, fredk said:
add to your shopping list a rotary blade knife of 45mm or 60mm diameter. You'll not be sorry.
I use one on any leather thinner than 1.6mm, or 4 oz. It really reduces that pull-out
Amen!
  • Replies 43
  • Created
  • Last Reply
Top Posters In This Topic
picked up a 45mm easier than a box cutter
  • 11 months later...
I know its been a while almost a year actually. ive bought some tools here and there but what stopped me from continuing leatherworking is sounds made from hammering a chisel. I was wondering if you guys knew any ways to greatly reduce the sound? I use a cheap hollow ikea table idk if that has any effect to the sound as well . Also thinking about just doing leatherworking on the patio of my apartment but late night hammering probably a no go.  Hows everyone been :gathering:
get a piece of marble or slate to do your stamping/banging against it will deaden the sound .
I made a special stamping table. Its basically a lot of 2 x 4 glued together vertically - maybe I'll photograph it tomorrow.
On this I place my slab of marble or special hole stamping block. Under the marble I use a  thick piece of neoprene rubber. I also have a thick piece of neoprene rubber under the table. This all limits the noise
A solid base will also increase efficiency. I've given up trying to set rivets on my work table, which started life as a computer desk and is just too flexible for hammering on.
Btw, you can do leather work without stamping... ;)
my tools for stitching are the mallet and chisel
The awl is silent and the gentle tap for just marking the stitches shouldn't carry through walls either.
and these are even quieter ~
until you nip your fingers with them!
