Can anyone help out with the model of this machine? Would it be something that could sew some lighter weight items like wallets?
You should look on that little plate under the round one for the model number.
Makes it easier for someone to help you.
Ferg
I’ve tried asking the seller that and either she’s incompetent and can’t tell me or doesn’t really want to sell it...
Singer 66 with an oscillating hook.  A later model with reverse.
This is not a 66. It has an end mounted horizontal axis bobbin. The model 66 have vertical drop in bobbins. It could be a 15 class or a model 201. The brass tag should have the model number. If that is missing, the serial number can be looked up on Ismacs and it will reveal the model and date of manufacture.
Posted IMHO, by Wiz
Back to the OP's question about its usability for wallets; it can sew wallet interiors with #69 bonded nylon thread using a #18 leather point needle. It will do better on slick top grain leather that doesn't get dragged by the steel presser foot. I would say it can sew about 6 ounces of small leather pieces; 8 ounces soft temper max.
Posted IMHO, by Wiz
9 hours ago, Wizcrafts said:
This is not a 66....
You might want to take another look at it, Wiz.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Thanks to all have replied!
  • 2 weeks later...
It's a 66.  The Singer 15 has the tension dial on the end plate.  The 201 has a little white power switch at lower right.  I don't know how you can tell the orientation of the hook under a cover plate.  The 66 is really only suitable for fabric or maybe very light leather.
