edwardmorris
What tools should I get and how do I do this?
Hello All, this is my first post here. I'm new to leather work and have been reading and watching videos to get the basics right for a while now. I feel I'm at the stage where I can start practicing so I ended up buying some leather and basic tools when Tandy had a sale recently. So far I have the B200 beveler, a small pear shader and one camo/border tool. I've been playing around with some of the scraps of Tandy's 8-10oz Superior Oak to figure out moisture content stuff and I've got a little ways to go :). The end goal is to be able to bevel straight lines and curved corners at some point. What I can't seem to figure out is what tools do I need to get this effect which almost looks like a round hose/pipe/tube. I've linked some images below.
IMG_8603-Medium.jpg?fit=1152,768&ssl=1
And the border, almost a perfect round tube
IMG_6704-Large-1.jpg?fit=1620,1080&ssl=1
And also how to do and what tool to get this beveling ridge right?
IMG_8606-Medium.jpg?fit=1152,768&ssl=1
 And finally, what kinda tool do I need to get this effect for a background?
IMG_6710-Large-1.jpg?fit=1620,1080&ssl=1
Any help will be really appreciated! BTW I've seen the video 'cut less bevel more', in my trials so far, this has worked the best. I will post pictures of my practice work as soon as I'm able.
Well . . . first off. . . welcome . . . glad to have you aboard . . . we were all in your shoes one day in the past . . . some recently . . . some back about Noah's day or so.
But anyway . . . put that belt back in a drawer . . . and take a shot at something much simpler.  That belt is way up on the totem pole of expertise . . . and quite honestly . . . you will be a while getting there.
Wallet kits are probably the very best learning tool out there . . . many come with detailed instructions for each part . . . a tool list you will need . . . and you can get the necessary "work" feedback relatively quickly . . . to see what you are doing.
Plus they make a special gift for a brother, father, friend, etc . . . here is one that is good to start with:  https://tandyleather.com/collections/kits_wallet-card/products/premier-wallet-kit
The swivel knife (you did not say you had one) is the backbone of leather decoration.  You HAVE TO get it and learn how to use it . . . FIRST.
Then shading, backgrounding, beveling . . . they will come.
Practice makes perfect . . .
May God bless,
Dwight
That rounded border can be done with a push beader or a beader blade in a swivel knife or a slicker in that profile. It takes a lot of practice to do it that nicely. the backgrounder looks like an E-294 these may be available from Springfield Leather.
Thank you Dwight for the warm welcome. No I do not yet own a swivel knife, most of the work I intend to do involves straight lines and I read/saw vids saying a groover/spoon tool works better, so I have that instead. For a starting project I was thinking more on the lines of a regular old belt with a buckle, with maybe a little border/simple tooling decoration instead of a wallet. The more I look at my practice pieces (pix soon I promise, need to get them off the camera), the more I'm convinced the B200 beveler isn't anywhere near as steep enough.
Thanks! I searched for both and came up with nothing on the beader front :( but I did find the backgrounder so thanks again! Do you know a part/model/maker anything I can use to find the beader?
Also new question, what tool is being used here?
Just a basic 1/4" beveller. The user has used a swivel knifr to impress the line just behind the rolled edge, now they're working along it to slope tjt inner edge away. The shot's been set up, because the leather's not been cased.
2 hours ago, Rahere said:
It's very possible a lot of the WWF work's hot-pressed, where the pattern's been made in steel.
Yep:yes:
My very first purchase of new stamping tools was  a ' basic 7 piece set' , that included some basic stamping tools and  a swivel knife .  But I also  bought some S/H tools from the same shop for a few bucks each, a few modelers, stamping tools, edge bevellers  etc.  I already had a sharp knife .  You don't  have to go for new tools if you don't wish to, depending on your budget, and how far you wish to go .
HS
1 hour ago, Handstitched said:
Yep:yes:
HS
Money can't buy you experience or skill, though. Far better to start simple and get what you need once you know what it is you need. And note, need is not to be confused with want.
Thank you Rahere! The pix I posted in the first post are the work of a famous individual, and its all by hand (guy is amazing). I don't expect to get that good on a project budget and timeline but I will pursue something good looking and close to those designs. Basic tools aside, for specific ones that will me achieve that specific look, I will likely end up buying them as I do plan on using them for a few smaller projects as well. Just want to be sure before I buy things :) I need help figuring out a beveler that will give me steep slopes, and also a part number for the push beader mentioned earlier on this thread, I can't seem to find anything that looks like it will do the trick.
Here are some pix of the practice scraps, I will do my best to describe the experiments.
1. Is the best results I've had so far. For this, I tried the "cheat" to get to the right water saturation by spraying the back and wetting the front with a damp (not full wet) sponge, then tooling within the next few mins once the surface dried enough. Had the best results with this method, and even tried a small/mild curve.
2. Is the piece that I wet in a similar manner, but then beveled small areas as they started to dry up, going from still wet to nearly dry, with the best result happening leaning towards nearly dry (on top at least)
3. Is the piece that I submerged till the bubbles stopped (few seconds) then left it alone for 24 hrs on a flat glass sheet. The outside line came out dead straight but then the piece became too dry. I wet it again to do the inner (left) line and that wasn't as perfect (probably my haste). I also beveled the corner with the tandy #3 edge beveler and gently sanded with extra fine grit just a little to get a nice rounded edge (still not the tubing effect).
4. Is the first practice piece, submerged wet then worked on it in about 4hrs as it had already dried out quite a bit somehow. The lines came out mostly ok, then the piece warped funny after drying and look horrid now :D
Very true.  Thats why I didn't spend a fortune on tools  etc. in case leather work wasn't for me, glad it was though  :) If it wasn't, I'd sell or donate the tools to local community group.
 I borrowed an AS  pattern book from a local  and photo copied it, I also borrowed a book from our local library....the only book on leather in the entire library  :)
HS
On 6/9/2021 at 4:41 AM, buzzardbait said:
Barry King makes push beaders and beader blades for a swivel knife.
Thank you! That does look like the right tool, but wow is BK stuff pricey! I might just have to go for it as I need to achieve that look. BK also has some steep bevelers, but I can't quite figure out what size to get as their website is somewhat user unfriendly for people not "in the know". Any suggestions?
On 6/11/2021 at 5:31 AM, buzzardbait said:
Contact BK and ask them to send you a sales flyer, the stamps are shown actual size in the flyer.
Thank you! I was able to speak with someone over there and I've sent them pics with details, hopefully I'll hear back soon and get what I need. In the meantime, I will move the conversation around my practice pieces to the getting started forum (seems appropriate). Thank you all for the help!
Continuing here
Continued input and advice would be much appreciated!
