Members homesewnrose Posted June 20, 2021 Members Report Posted June 20, 2021 I've been making custom bags, purses and totes out of heavy cloth fabrics for the last several years and have been struggling with my two home sewing machines (Brother CS6000i and Janome HD3000). I want to upgrade to an industrial sewing machine but am a bit overwhelmed by the range of choices available. I'm looking for advice on what type or types of machines and needle systems would be best suited for working with somewhat bulky, home decor and upholstery fabrics. Where my current machines struggle is when I sew bag straps over 7/16" thickness, gussets, and top-stitching smaller bag openings. I use a wide variety of fabrics. Most of my work today on my home sewing machines is done with #14-16 needles. I'm frequently breaking needles, and I suspect this is because the machines just aren't big enough to wrestle all the fabric through, things drag and the needle snaps. For some projects I probably need to go to a bigger needle, but #16 is the largest my machines supports. I think a cylinder arm sewing machine may be helpful but I have no experience with one and most of the advice I've found online about cylinder arm machines is related to leather. Plus many of the cylinder arm machines I've come across use needle systems designed for leather and not upholstery fabric. Some sewing machines I've come across that look like they may work for me are: Atlas AT335 (DPx17, 135x17 needle) Cobra Class 26 (DPx17, 135x17 needle) Any feedback or advice would be appreciated! Below are some examples of the types of projects my machines struggle with: Quote
Members Kwaaked Posted June 20, 2021 Members Report Posted June 20, 2021 I have a Consew 7360RH-R SS in my shop and it's meant for lightweight to heavy weight. While I don't make jeans on it (18 oz and above), I can hem jeans just fine with it. It takes the standard 16x287 system, and I use upholstery fabrics to make tote shopping bags on it with no problems. (C&P) Heavyweight fabrics such as jeans can be sewn by changing the needle plate, feed dog, foot, stitch regulator, hook and needle bar. I have founds parts are pretty affordable for the machine (I have no had to replace anything, but I did look into this modification before I got my Singe #3). You might be better off talking to an industrial machine store and talking to them for recommendations in your budget. Quote
Members homesewnrose Posted June 20, 2021 Author Members Report Posted June 20, 2021 4 hours ago, Kwaaked said: I have a Consew 7360RH-R SS in my shop and it's meant for lightweight to heavy weight. While I don't make jeans on it (18 oz and above), I can hem jeans just fine with it. It takes the standard 16x287 system, and I use upholstery fabrics to make tote shopping bags on it with no problems. (C&P) Heavyweight fabrics such as jeans can be sewn by changing the needle plate, feed dog, foot, stitch regulator, hook and needle bar. I have founds parts are pretty affordable for the machine (I have no had to replace anything, but I did look into this modification before I got my Singe #3). You might be better off talking to an industrial machine store and talking to them for recommendations in your budget. Thanks for your reply. That looks like a great machine! And it looks like it has a lot of room to move bigger bags around. My worry is topstitching the smaller bag openings and being able to work them around the arm of the machine, that one looks a little large. However, the needle range looks great! Quote
kgg Posted June 21, 2021 Report Posted June 21, 2021 The Atlas AT335 ($1495) is a class 335 cylinder bed Chinese clone machine which is going to limited you to V92 as a maximum thread size while the Cobra Class 26 ($2255) which I think is a Class 341 machine with a maximum thread size of V207. Most any cylinder bed machine can accept binder/ folder attachments if you need / want them. Based on your photo's of your trouble projects I would firstly recommend a flatbed triple feed (needle, feed dog, pressor foot) over a cylinder machine in the upholstery class of machines like a Juki DNU-1541S ($1500 US). The price of binders and folders for the flatbeds are considerably cheaper ($15 versus $100) and easier to install. If you don't need a triple feed I would recommend a Juki DU-1181N ($1400 US) which is just a walking foot (feed dog and pressor foot). My main machines are: i) Juki DU-1181N (Walking Foot) which is used mainly for thinner fabrics and binding. Mostly using V92 but have used V138 on top and in the bobbin. I just completed a nice little kneeling pad (42"x 3.5" x 16") with this machine using 21 oz cotton canvas with military lapped seams and double reinforced corners using 21 oz natural canvas. ii) Juki DNU-1541S (Triple Feed) which is used mainly for thicker items like double 3/4" hard back Sherpa. Mostly using V92 and V138 on top and in the bobbin. It hates thin stuff and has to be dumbed down to do them properly. The 1181N excels at the thinner stuff that the 1541S hates. iii) Kobe LS-1341 (Triple Feed clone of the Juki LS -341) which is used mainly for thicker items with curved or round surfaces and binding. Mostly using V138 on top and in the bobbin. Keep in mind there is no ONE machine that will do everything. I would recommend you buy a brand name machine and that you take a sample of your materials or projects to a dealer and test drive a few different machines. Buy Once, Cry Once kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
ButtonLady Posted June 21, 2021 Report Posted June 21, 2021 8 hours ago, Kwaaked said: You might be better off talking to an industrial machine store and talking to them for recommendations in your budget. 51 minutes ago, kgg said: I would recommend you buy a brand name machine and that you take a sample of your materials or projects to a dealer and test drive a few different machines. I third this suggestion. When I was ready for an industrial, I made an appointment with a dealer and showed with a bag stuffed with typical fabric. If a dealer isn't comfortable with you test driving some machines... find another dealer. Quote Sewing Machines: Juki DNU-1541 and waaay too many home machines and sergers... Button Machines: Osborne, Wade, Defiance, Maxant, Handy Jr. #1 and #20, Fasnap PM5 (and too many dies to count)
Members Kwaaked Posted June 21, 2021 Members Report Posted June 21, 2021 I bought mine online,. but the dealer had a list of service people that could come to my area and did a video call of all the fabrics I would sew with and then some...so even if one isn't nearby the can always do the zoom calls. Quote
ButtonLady Posted June 21, 2021 Report Posted June 21, 2021 9 hours ago, Kwaaked said: I bought mine online,. but the dealer had a list of service people that could come to my area and did a video call of all the fabrics I would sew with and then some...so even if one isn't nearby the can always do the zoom calls. This seems like a really good alternative to in-person road testing. I forget that not everyone has the luxury of living within driving distance of a dealer (or several dealers). Quote Sewing Machines: Juki DNU-1541 and waaay too many home machines and sergers... Button Machines: Osborne, Wade, Defiance, Maxant, Handy Jr. #1 and #20, Fasnap PM5 (and too many dies to count)
MtlBiker Posted June 21, 2021 Report Posted June 21, 2021 @homesewnrose - Funny, those are the exact same two machines I started with. I liked the Brother 6000i, but it just wasn’t strong enough for what I wanted to do. I replaced it with an HD3000 which I still have and use. But I only use it for very light sewing, such as masks, etc. and light repairs. It’s a surprisingly good machine. As I got more involved with sewing, using more webbing, heavy canvas, Cordura, etc. and many layers, I found I needed something a lot more powerful. Not knowing much about industrial machines, by luck I came across a dealer demo Consew 206RB-5 at a good price and now after more than a year using it, I LOVE IT! That’s a flatbed machine. I’m sewing primarily with v92 threads and use 135x17 needles for most fabric (usually size 20) and 135x16 for leather. (I’m just getting into leather but don’t have much experience yet.) About 6 months ago I added a cylinder bed machine, a Techsew 2750 Pro. And that’s really a nice machine also. But as KGG said earlier in this thread, it’s pretty hard (impossible?) to find one machine that does everything. I use the Consew for the vast majority of my sewing but the cylinder bed machine is great for sewing the openings of bags (which I’m making mostly these days). Now, after the few months of experience I have, if I had to choose only one machine, it would be the Consew 206RB-5 (or equivalent). That’s the one machine I really couldn’t do without. Best of luck with your search! Quote Current machines: Janome HD3000 and Skyline S5, Consew 206RB-5, Singer Profinish serger, Techsew 2750 PRO, Sailrite LSZ-1 Premium, Consew DCS-S4 Skiver
Members Tejas Posted June 21, 2021 Members Report Posted June 21, 2021 One kgg suggestion is a Juki DNU-1541S. If that machine interests you, you might want to also consider a Juki DNU-1508N. The primary interest when I bought the 1508 was marine sewing applications. In addition to marine canvas, cushions, boat blanket which is quite heavy and some sail repair, I have also sewed leather and fabric bags. The 1508 is top-load bobbin machine, which I prefer. The 1541 is a bottom-load bobbin machine. Quote
