I just installed a Consew CSM-3000 servo motor on my Juki 1508N and fabricated a speed reducer for it. Everything is working fine, just the way I wanted it. The problem I am having is getting a new Needle Positioner to work. After I installed the NP it does nothing to position the needle, as if the control box doesn't recognize it. There is one page of instructions with the CSM-3000 motor that gives very little info about the control box. This is a newer control box than the one pictured on the Consew website, it has 4 buttons instead of the two shown. I've tried searching online, including the Consew site with no luck. Consew doesn't even list the CSM-3000 on their Resource Page. The little info I have found on an Upholstery forum indicates that the needle positioner is located in the menu as "U1", but that does not even show up when I cycle through the menu. Also the panel shows "U 13" for a brief time every time I turn it on and then shows the set speed... not sure if that is some error code or what?  Everything else is working fine. Any help would be much appreciated.
Are you positive it has a Needle position function, as it looks like some consew motors don't have that option
Mi omputer is ot ood at speeling , it's not me
Well, I've reached out to the Consew tech support team through their website twice in the last 2 weeks with not a single response. Nice customer service! I've been looking for a used cylinder arm machine for a while, but Consew will definitely NOT made my short list!
  • 2 weeks later...
I called and spoke to a Consew Rep last week. He admitted he didn't know anything about their motors or controls. He asked for my email address, said he would try to find some better instructions dealing with the control box menu and get that right out to me. Obviously there is none or he didn't look! My last Consew product purchase.
Expand
HAHAHA LOL  .. I tried there service Dept. for a fix of new Consew servo I bought couple years back .. Servo is one of there nice model . 750 watt, 4 button programmable csm3000 .( No NPS ) . Looks pretty much same as your model Pic.
Mine ... Turn on . It hammers-out 5 stitches on the power-up .
Consew customer service Center . They are a Joke , and All They Could Tell Me Was , ...  "send us a video of your problem "  .
I hung-up the phone and went back to work . Labeled---> ' PREMIER BY CONSEW ' .. my Ass . Consew CS is worthless on giving usable knowledge to customers mechanical problem .
Expand
Mine has always turned a few revolutions on startup.  I thought it was a feature.  :P
Edited by bj139
  • 3 years later...
It sounds weird and could just be a one off but I just had the same issue.  It would light up when down but would not stop the needle in the correct position.  I tried factory resetting the controller, unplugging the positioner, etc and was getting ready to pack it back up.
Here is what worked as a last effort.
I had everything connected.  Shut off the controller.  It still seems to have a little bit of residual power.  I operated the pedal to force it to use the rest of the power.  Looked like there was a brief error message then it shut down.  When I turned it back on the positioner worked.  SMH.
FWIW, a CSM 3001 controller.
Good luck.
