Members courtney Posted July 10, 2021 Author Members Report Posted July 10, 2021 Thanks guys, it sounds like it’s probably ok then. I don’t really need it to do those long stitches, I just started wondering if there was something wrong with it, since I had read about bigger stitches on other machines. Quote
Members jimi Posted July 10, 2021 Members Report Posted July 10, 2021 Yeah, sorry for the small picture of the 45k21 courtney but you can see it says max stitch length 1/4 " Quote
Members Sham Posted December 28, 2022 Members Report Posted December 28, 2022 My 45k25 seems to stitch pretty well, but when I set it to the longer stitches it immediately leaves loops and knots on the underside. I’ve tightened the top tension until it’s way too tight and still does it. I’ve played with both top and bottom tensions. Tried a 25 needle 277 thread. When I move it back to shorter stitch the loops go away. …Also!…this is my post, “courtney” and I’ve been locked out, forgot password for a really long time, tried so many times to reset, and contact admin, but never get a response/email…can someone help me please? Quote
Members Constabulary Posted December 28, 2022 Members Report Posted December 28, 2022 @Sham Post pictures of your threaded machine please. When you have tightened the top tension and you still have loops on the bottom I would assume too much bottom thread tension or maybe a too weak top tension spring. But I only can guess w/o knowing your machine. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Sham Posted December 28, 2022 Members Report Posted December 28, 2022 You would think that’s it, but the bottom tension is very light, and the top tension is so tight I’m breaking needles pulling thread through by hand..,only as a test, I’ve adjusted it all different ways. Is there any reason though that everything would change only at the longer stitch length though? Cuz it is fine at shorter spi Quote
Moderator Wizcrafts Posted December 28, 2022 Moderator Report Posted December 28, 2022 11 minutes ago, Sham said: Is there any reason though that everything would change only at the longer stitch length though? Cuz it is fine at shorter spi I can't do anything about you forgotten password, but I can offer a suggestion about the change in tension with longer stitches. In effect, with all things being well balanced at short stitch lengths, when you make much longer stitches you draw more top thread than bottom thread and the top tension decreases somewhat. When this happens to me, if I can't reduce the bobbin tension any more, I move up one needle size. I also increase the throw of the check spring so the top thread is held taut longer. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Sham Posted December 28, 2022 Members Report Posted December 28, 2022 Thank you @Wizcrafts & @Constabulary, I was thinking a bigger needle might do it, but 25 was as big as I had w/ 277, I did put some thin thread on top but it broke.. the check spring, I’ve never adjusted, was thinking maybe that would help, cuz I have that automatic thread regulator tab thing, that says it’s for the purpose of adjusting to different thicknesses, but I don’t really understand. I’ll go fool with it a little more Quote
Members Sham Posted December 28, 2022 Members Report Posted December 28, 2022 Well, I don’t think adjusting the check spring did much, but I put 69 in the bobbin and top with a 25 needle and light tension through 9 oz. Veg and it worked fine, even with that tiny thread the big holes really weren’t that noticeable. Maybe. A 28 needle w/ 277? Quote
Moderator Wizcrafts Posted December 29, 2022 Moderator Report Posted December 29, 2022 7 hours ago, Sham said: Well, I don’t think adjusting the check spring did much, but I put 69 in the bobbin and top with a 25 needle and light tension through 9 oz. Veg and it worked fine, even with that tiny thread the big holes really weren’t that noticeable. Maybe. A 28 needle w/ 277? I use a #18 needle with v69 thread and a #25 with v277 thread. Your needle is the right size for 277. Something else is wrong. That something is either causing the top thread to lose tension on the upstroke, or the bottom thread is hanging up as the top thread goes around the shuttle and tries to pull it up. Watch the thread go around the shuttle and see if the bobbin thread is getting caught on the feed dog or its mechanism, or the hook itself on the way up. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Sham Posted December 29, 2022 Members Report Posted December 29, 2022 @Wizcrafts, ok, I’ll see if I can make a video, and do some tests Quote
